I have a 2013 Mk7 Gti DSG with approximately 90 000km on the clock
About 6 weeks ago the water level light came on and I topped it up with 300ml of water, no issues since
On Friday oil warning light came on and I put two pints into the car, all sorted.
Is there anything I need to worry about with the above? My thoughts were that it shouldn’t use oil between services, same for the water?
My last car was a Polo Gti and the engine went on that. My cars extended warranty expires in December, should I look to trade this one in and get something else?
2013 - Mk7 Gti 90 000km - Oil and Water
Current: 2013 Golf 7 GTi (White)
Ex: 2011 Polo GTi 6R (Candy White)
Ex: 2006 1.9 Golf 5 TDI (Blue Graphite Pearl)
Ex: 1996 4.6 Range Rover (Niagra Grey)
Ex: 2007 1.6i Velocity STD (A/C T/B S&G)
Ex: 2004 1.4 Chico (Tossa Blue)
Ex: 1976 1600 Beetle (Black)
- Membership No: 2033
Re: 2013 - Mk7 Gti 90 000km - Oil and Water
Check for slow water leak (OEM has dye in it, to see under UV light) Maybe waterpump? How often you check oil?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
To tell the truth I never check the oil. This is the first time I have ever checked it. Yeah not ideal I know, my thinking is that it shouldn’t use anything between services.
- Wolf Mk2 16V
Leaky thermostats/radiators are common on Mk7 Gti's, I had mine replaced 3 times!
As for the oil, I use a liter between services, it has been like this since I got the car (on 30 000, now on 108 000) Turbo motors burn a bit of oil, nothing to be concerned about. How long have you owned the car?
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
Have had the car for just over 2 years, might be that its always used a little oil and I have never known it. Will get them to do a check for the water leak.
