Golf 6 Gti clunk under braking
defyingcaesar
Registered for: 7 years 6 months
Car Model: G6 GTI
Post by defyingcaesar »
Hi guys, Jethro here
Recently picked up a used G6 GTI at an auction with some damage to the right side. They did a pretty mang job fixing it and the fitment wasn't too great but now everything lines up well now that it's all been fitted properly and with a spray she'll be set. No visible undercarriage damage and the control arms look untouched. Now I've got an issue under hard braking and when reversing under full lock, normally to the left. It's a half click/thud from the right side (the damaged side)
Tonight under hard braking it almost felt as if it lost braking power and rolled forward strangely.
Got the car scanned and it's all good apart from the evap valve which will need replacing. If anybody can provide some insight as to where to start that'd be greatly appreciated :D
Cheers
Re: Golf 6 Gti clunk under braking
Hub, Hub carrier / wheel bearing. Take it all apart and look for damage. Start with putting a new bearing and hub in as that probably took a knock and was not changed. Don't mess with that stuff. It will kill you and or somebody else.
defyingcaesar
Car Model: G6 GTI
Thanks Panic. Will have a look :D I figured it might be a hub related issue. Either that or subframe.
