Mk5 GTi Vibration at speed
HI Guys,
Please assist,
Ive recently bought a MK5 GTi DSG , and have noticed at speeds above 110km/h the car has a vibration (the whole car literally shakes), I initially thought it would be a wheel balancing issue, but it isn't. Ive had the wheels balanced, and high speed balanced, and no buckles or any other issues were found with the wheels.
I eventually sold the wheels and put a set of 19's on, and car is doing exactly the same thing, any ideas as to what it could be,
Please assist,
Re: Mk5 GTi Vibration at speed
Check wheel bearings..maybe a suspension specialist ad they check various rubber components ie.suspension bushings
- ICE King
Does the steering wheel shake as well?
As said, bushes and have your CV's,drive shafts checked as well.
- vernymac
- Wheel Whore
- Registered for: 10 years
- Car Model: VW MK5 GTI
- Membership No: 3239
You will have to loosen the driveshaft nut to check the wheel bearings (possibly remove the cv joint from the hub to check if its end of life) .Modjo wrote: ↑Wed Aug 15, 2018 10:42 am HI Guys,
Please assist,
By shaking the wheel, you cannot determine if its worn or not unfortunately.
- Car Model: Mk5 gti
I have the same problem with mine I've balanced the tires I've rotated them and even changed 2 tures but still have the same issue plz let me know if u find the problem so I can fix mine too thanks
viewtopic.php?f=11&t=217296
Previous :too many to list
- Dub rox
- Car Model: Citi sport 1.4i
You could also check your shock ubsorbers while your at itModjo wrote:HI Guys,
Please assist,
Sent from my VFD 1100 using Tapatalk
My car makes a squeek squeek squeek cluck cluck cluck sound both at the same time when I brake at low speeds say 20km could it be a brake caliper or something that is brake related it's got new discs and pads that the previous owner installed 2 months ago just before I bought the car
- Dub rox
Do you feel any shudder under brakeing?Trishen94 wrote:My car makes a squeek squeek squeek cluck cluck cluck sound both at the same time when I brake at low speeds say 20km could it be a brake caliper or something that is brake related it's got new discs and pads that the previous owner installed 2 months ago just before I bought the car
There might be a slight shudder but very hard to tell ...car went to Supaqik they said it was shocks ...about 5k later problem is still there
My buddy drove my car says he can't feel any shudder on the brake but at high way speed the whole car has a slight shudder as if a tyre is not balanced
- Dub rox
Did you brake hard at any point??? Could be flat spots on the tyres aswellTrishen94 wrote:My buddy drove my car says he can't feel any shudder on the brake but at high way speed the whole car has a slight shudder as if a tyre is not balanced
- Dub rox
Some places don't tighten the shock mount nuts properly and they can loosen from vibration and movement of the shocks so if your shocks were done i would recomend you check all 4 and see if everyrthing is good and tight just to eliminate that as a possibilityTrishen94 wrote:There might be a slight shudder but very hard to tell ...car went to Supaqik they said it was shocks ...about 5k later problem is still there
Will do that tomorrow afternoon and how would I check for flat spots on the tyres ? Will Supaqik be able to check ?
- Dub rox
They should be able to check for flat spots and check everything suspention wise, just make sure you are there checking everything with them otherwise you could end up enduring un neccesary costs.Trishen94 wrote:Will do that tomorrow afternoon and how would I check for flat spots on the tyres ? Will Supaqik be able to check ?
- Car Model: White-G5 GTi
Mine did same,..ended up to be cracks in the disks. Changed front disks and brakes problem solved R1800 cost
Hi camo but the discs and pads r new I'd say 3 months old how could that happen do u think it was cheap quality il ask supaqik to check if they not cracked coz I personally cannot see any cracks ...or r they not visible to the naked eye?
Hi guys who does skimming of the brake disc while its still on the car ?
Hi guys just some feedback so u guys know I've been struggling with this vibration also on my car for the passed 4 months...ive spent a **** load of money 1st was
Front brakes and discs ...car still shuddered then was shocks ...car still shuddered ...then i sent it for a full suspension check came back with no faults I then balanced and rotated tyres 4 times at 4 different shops...car still shuddered then I replaced 2 tyres...car still shuddered ...eventually i wanted to sell the car but I said one last try at a small allignment shop near my house guy looks abit old I'd say 50+- says R120 for a suspension check I said ok do it he also says can't see anything besides control arm Bush's that are still ok and won't cause this severe shudder then he charges me R100 a tyre to do HIGH SPEED BALANCING and guys this guy is a magician he spins the wheel approximately 80km or 100km whilst on the car and it shows which wheel is shuddering he then started placing weights and taking out weights without the machine telling him what to do and guys the shudder is down to nothing now I'm so happy now that I think I'm going to keep the car ...it still has a very slight shudder but its coming from the back disc they kinda worn out but u cant even feel it so I'm good to go now if any1 has the same problem ...try the high speed balancing
Thanks guys
Thanks guys
Please share this guys number
GLAD SORTED
