vw 2e turbo clutch problem
hi guys i am strugling with my clutch on my caddy i had n button clutch made for it so i fitted n luk pressure plate it was fine for about 2 months but the thing is slipping like crazy now it had play on the pedal so.can you guys give me some advice on this is there n place were you can buy n decent clutch and pressure plate or at least n pressure plate with n better clamp load
Re: vw 2e turbo clutch problem
Tell us in which area are you to assist directing you to someone.
Norbrake should be able to help you out.dubworx wrote: ↑Thu May 17, 2018 10:06 pm hi guys i am strugling with my clutch on my caddy i had n button clutch made for it so i fitted n luk pressure plate it was fine for about 2 months but the thing is slipping like crazy now it had play on the pedal so.can you guys give me some advice on this is there n place were you can buy n decent clutch and pressure plate or at least n pressure plate with n better clamp load
Thanx for the reply papajo wil give them a call today
