2010 audi A4 1.8t timing chain
- Car Make: Mazda, Seat
- Car Model: Mps, Ic
Hi guys please help, a friend is fixing a 2010 audi A4 1.8t so he has done the timing nd fitted a new chain, guides as well as tensioner bt when he starts it it loosens the chain, what could be the problem? Nd he has tried it so many times bt still loosens the chain.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Re: 2010 audi A4 1.8t timing chain
Panic should pop in shortly to advise.
- Car Make: Nike
The Guide uses Oil presure to keep chain tensioned, seems like there is no oil presure.Mricco wrote: ↑Tue Apr 24, 2018 6:57 am Hi guys please help, a friend is fixing a 2010 audi A4 1.8t so he has done the timing nd fitted a new chain, guides as well as tensioner bt when he starts it it loosens the chain, what could be the problem? Nd he has tried it so many times bt still loosens the chain.
Check where the guide bolts to the head if the gasket is not blocked or the oil hole blocked.
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
- Unobeat
Interesting Rudi.Rudi46 wrote: ↑Tue Apr 24, 2018 8:02 amThe Guide uses Oil presure to keep chain tensioned, seems like there is no oil presure.Mricco wrote: ↑Tue Apr 24, 2018 6:57 am Hi guys please help, a friend is fixing a 2010 audi A4 1.8t so he has done the timing nd fitted a new chain, guides as well as tensioner bt when he starts it it loosens the chain, what could be the problem? Nd he has tried it so many times bt still loosens the chain.
Thank u guys will check
So if it's not the oil pressure what else could it be?
Isn't it the tensioner that uses oil pressure?
Did he use the correct tools and the correct way to tension the chain. there is a certain sequence of events that you have to follow and you have to have the lock tools to that.
He has done quite a lot of these cars before including golf 6s gti so don't know whats happening
no then I give up. It's virtually impossible to say without seeing it and his method.
I understand
