2011 B7 Passat 1.8 tsi dsg, Blow of valve or diverted valve?
Kabir M
Registered for: 6 years 1 month
Post by Kabir M »
Hi everyone, I need to know what this car comes wish and what do I need to know when I want to install a Forge motorsport blow off adapter?
Re: 2011 B7 Passat 1.8 tsi dsg, Blow of valve or diverted valve?
fuelling systems that uses MAF (airflow meter) must use a diverter valve. If you blow it off you are screwing with the fuelling everytime you let off the throttle. It is bad for the engine in the long run.
