9N3 Polo GTi boost issue
madhoshival
Registered for: 8 years 6 months
Car Model: 9N3 GTi
Re: 9N3 Polo GTi boost issue
Post by madhoshival »
panic-mechanic wrote:No I give up. Burn it.
We all have given up Image
The thing is that if it does exactly the same with a small turbo like the k03 then you have a fundemental mechanical f-up somewhere. So either very low comprression or a timing issue of some sorts. Unless you have a massive leak that you have missed with your testing. So be SURE SURE of those things.
madhoshival
Car Model: 9N3 GTi
panic-mechanic wrote:The thing is that if it does exactly the same with a small turbo like the k03 then you have a fundemental mechanical f-up somewhere. So either very low comprression or a timing issue of some sorts. Unless you have a massive leak that you have missed with your testing. So be SURE SURE of those things.
The ko3 still boosted.. but took a much longer time than it should.. I only got full boost by 4000rpm.
It's just more evident now because of the bigger turbo.
MarshallGTi
Registered for: 13 years
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Post by MarshallGTi »
Far left suggestion, is there not maybe a small crack somewhere like the intercooler/manifold that only opens up when the metal gets warm? If you did the boost leak tests with a cold engine bay maybe the crack wouldnt be open and leaking? unlikely but seeing as everything else is in order?
Also do you have a boost gauge so you can see whats the air is actually doing rather than relying solely on VCDS?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
madhoshival
Car Model: 9N3 GTi
MarshallGTi wrote:Far left suggestion, is there not maybe a small crack somewhere like the intercooler/manifold that only opens up when the metal gets warm? If you did the boost leak tests with a cold engine bay maybe the crack wouldnt be open and leaking? unlikely but seeing as everything else is in order?
Did many boost leak tests and they're all holding fine. Tested to 2 bar.
I have a boost Gauge and its corresponding perfectly with what's being read by vcds.
