1.8T pre-delete paranoia
Aslam_mk4
SO FLUFFY, WE ALL GONNA DIE!
Membership No: 1824
Re: 1.8T pre-delete paranoia
Post by Aslam_mk4 »
What's the price on the fsu delete kit
Bagged mk4 2dr
"Ride or die"
Keshan_G
Registered for: 8 years 10 months
Car Model: Polo 9n3 GTi
Post by Keshan_G »
Aslam_MK4 wrote:What's the price on the fsu delete kit
About 450,
but contact Miggz, Epic service :wink:
'07 Blue Polo GTi 9n3
Powerflow 76mm DP- 63mm Zorst> 90deg intage/cone> Forge TIP> Forge Splitter DV> Forge Charge Pipe> Cupra FMIC> BC Coilies> R8 Coilpacks> 4Bar FPR > Devils Own Stage2 WMI
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Post by P1LAYA-ZN »
About 450,
What Deletes does this include ?
#Builtnotbought
ZiF_k
Car Make: VW Polo
Car Model: Gti
Membership No: 2029
Post by ZiF_k »
P1LAYA-ZN wrote:
About 450,
SAI/N249
Current: Big Turbo 20VT
Ex: 2003 Citi 1.4i
georgie
Registered for: 17 years 11 months
Car Model: 07 pgti
Post by georgie »
Deletes done. Fairly challenging at times but not too hectic. Cursed some of your names at certain points but all worked out ok in the end. No more sai noise :hurray:
The car also seems to do less stupid things and the dumping sound seems to be sharper/crisper lol.
The conduit was actually a huge PITA to fit lol
Only had a collosal F up with fitting the valve cover gasket but will get that sorted another time.
No CEL's or codes popping up so far.
Also managed to find the source of a random check oil light that popped up last week, even though the oil was full. The entire dipstick amd funnel was destroyed, it just broke into pieces. Replaced with barons parts, would like to source an aluminium set though.
07 PGTi
Ex: 11 BMW 320d
Ex: 12 Cross Polo 1.6
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Ex: 99 Polo 2.0 16v (ITB's, cams, etc)
Ex: 05 Fiesta ST, 00 Sentra 200gsi, 04 citi 1.4i, 94 Corolla 180i GSE ,92 cti, 73 Escort Mk1 4AGE twincam
georgie
Car Model: 07 pgti
Post by georgie »
Many thanks for the motivation chaps :thumbup:
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
dcmk4
Registered for: 9 years 11 months
Car Model: MK7 GTi
Post by dcmk4 »
Good to hear you finally made the jump into the unknown land of deletes :troll:
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
georgie
Car Model: 07 pgti
Post by georgie »
DCmk3 wrote:Good to hear you finally made the jump into the unknown land of deletes :troll:
That pump bothered me for 2 years bra :lol:
Fixed it before but ot worked its way loose again.
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
ZiF_k
Car Make: VW Polo
Car Model: Gti
Membership No: 2029
Post by ZiF_k »
Glad its sorted!
Ex: 2003 Citi 1.4i
georgie
Car Model: 07 pgti
Post by georgie »
ZiF_k wrote:Glad its sorted!
Shot bro!
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Pynoxim
Post by Pynoxim »
Now just another two years and you can get a remap xD
Also, just a note, THANAS does not have resistors BUT he does have the N249 and N112 plugged in with no hoses attached to them, they're just cable tied out of the way, essentially the same as resistoring.
Thursday Milkshake Crew
'00 GS2 Lexus GS300
georgie
Car Model: 07 pgti
Post by georgie »
lol, well hopefully the wait wont be that long. There are a few cosmetic things i need to get sorted before sw though.
As for my colossal F up I had with the tappet cover...
When i eventually got the tappet cover off, I realized that the gasket I had was completely wrong, not even near the one i needed (Thanks GW)
Had no choice but to re-fit the old gasket with some sealant. Cleaned up the cover and re-fitted. Then used my trustee Midas torque wrench set to 10nm.
8 of the 9 nuts tightened perfectly, last one snapped the stud before it made the clicking sound :(
I've been checking and no oil seems to be leaking out of the cover for now.
So now I need to have the stud issue fixed and get the proper gasket fitted at the same time :bang:
Does anyone have details to how one of these studs would be replaced?
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Post by THANAS »
Did it snap at the base of the stud or closer to where the nut would sit?
If at the top, remove the tappet cover and try turn it out with pliers or weld onto it and turn it out. If it sheared at the base it will have to be drilled out/helicoiled, get a thread guy out there for about R250. I have a guy I use quite often if you want his number.
georgie
Car Model: 07 pgti
Post by georgie »
THANAS wrote:Did it snap at the base of the stud or closer to where the nut would sit?
It snapped closer to the top so should be able to turn it out. I'm not keen on opening up again. Going to leave the gasket job to a pro to do while he services the car. I assume I can just take the broken stud to Bolt It and get a replacement? Unless anyone her knows the details of the studs? Also, would it not be better to just replace all the studs with bolts instead? Its strange to me how easily that thing snapped.
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Killerwatt
Car Model: S3
Post by Killerwatt »
Dude like i said in the torque wrench thread. The midas one does overtorque on the lower settings. I would nout use it under 40nm.
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
They snap because they get stretched by being over tightened by meat fisted gorillas.
Joke
The studs are mild steel therefore its not uncommon to break them. I wouldn't panic as even pro mackies do it on a regular basis.
THANAS
Membership No: 2035
Post by THANAS »
Tappet cover nuts are also torque-by-feel with a 1/4" drive, YOLO nuts imo.
georgie
Car Model: 07 pgti
Post by georgie »
What about replacing them with stronger bolts with the same thread pattern?
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Killerwatt
Car Model: S3
no need bro. They don't have to be that tight in the first place.
georgie
Car Model: 07 pgti
Post by georgie »
Killerwatt wrote:no need bro. They don't have to be that tight in the first place.
Ahhhh, pity. Will get a few of these studs made up then.
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Pynoxim
Post by Pynoxim »
Yeah, I usually tighten them using the screwdriver type socket tool with a 10mm socket attachment, you don't need much more than that.
'00 GS2 Lexus GS300
georgie
Car Model: 07 pgti
Post by georgie »
Managed to get the part number for these studs. Ordered full set from Barons. R14 each excl.
https://www.ecstuning.com/Volkswagen-Je ... /ES252395/
Ordered original gasket as well.
07 PGTi
Ex: 11 BMW 320d
Ex: 15 Fiesta ST
Ex: 04 Jetta 1.8T
Ex: 99 Golf VR6
Ex: 87 Fox 1600
Dookie77
Registered for: 11 years 9 months
Car Model: 2014 Golf MK4 GTI R
Post by Dookie77 »
Who would be able to do the SAI delete for me in CPT? And what sort of costs am I looking at?
Current ride: 2004 Image Golf IV GTI R
Ex ride: 2008 Image 9n3 Polo 1.6i Comfortline
Ex ride: 2012 Image 6R Polo 1.6i Comfortline
Ex ride: 2007 Image Golf V GTI (Stock BWA)
ZiF_k
Car Make: VW Polo
Car Model: Gti
Membership No: 2029
Post by ZiF_k »
Dookie77 wrote:Hi guys
Speak to Mike from Thanas. 0844524190
Ex: 2003 Citi 1.4i
