1.8t Boost fluctuation
SoDub
Chairman
Chairman
Car Model: Seat Ibiza Cupra 20VT
Membership No: 1998
Post by SoDub »
Hi Petrol Turbo peeps. I seem to be having a tiny bit of fluctuation. Now that I think of it it has probably been there since I bought the car.
But after hooking up a boost gauge and reverting to a stock DV I can see it happening in the higher gears. Load the car in 4th and 5th and boost climbs to 1.2 but drops to between 1.05 and 1.1 for a millisecond then back up again.
Sometimes it will hold once back up to 1.2 but occasionally will drop sliiiightly again and return to 1.2.
We suspect the car has a leak of some sort as it is reading -0.6 on idle. We checked all the DV piping and the DV seems fine but it could be on it's way? Could it be the n75 is starting to die? PCV faulty?
Anyone else had this issue?
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
Stompie
Boostleak Guru
Registered for: 12 years 9 months
Car Model: 2006 120D
Membership No: 1843
Re: 1.8t Boost fluctuation
Post by Stompie »
Sounds like the Actuator spring that has gone weak causing it to open and close under boost.
BMW 120D E87
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
I'm hoping its something not as drastic! That leak we heard with James and Mig could be the bastard causing this.
Maybe I swing passed this weekend to find it quick and then see from there if the issue persists?
Car still makes required boost and does not overboost at al - will not go over 1.2 bar and runs well. It's just that little fluctuation.
Mig picked it up when he drove my car when I first got it and we thought it might be the TC kicking in a bit.
Vortex has quite a list of things it could be but the main cause is usually leak or a DV on it's way.
The actuator spring being weakened should result in irratic boost and won't hold peak boost at all - But who knows :(
El Toro
Blossom
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
Sounds bad maybe you should just sell the car to me :troll:
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
dazza wrote:Sounds bad maybe you should just sell the car to me :troll:
Deal! Put monies in my account and let's do this :troll:
El Toro
Blossom
Nikz_tsc
Registered for: 11 years 4 months
Car Model: Mk7 GTi
Membership No: 2093
Post by Nikz_tsc »
Stompie wrote:Sounds like the Actuator spring that has gone weak causing it to open and close under boost.
+1 with what Stompie said. Had this issue on my 9n3 and it got progressively worse. Swapped out the actuator for another oem one and the fault went away.
Current: Mk7 Gti
Previous: Ibiza Cupra 20vT; Polo GTi 20vt
TSC Garage
Performance Tuning Solutions
info@tscgarage.co.za
0619955604
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
Nikz where did you manage to get another actuator...flip i cant find one anywhere so just did the external spring mod on mine and has been working 100% for the last 3 years.
Ive heard that the Forge actuator is a pain in the ass to set up perfectly and causes **** or something,
BMW 120D E87
Bev0_tsc
Registered for: 11 years 7 months
Car Model: '08 Polo Gti
Membership No: 2087
Post by Bev0_tsc »
Stompie wrote:Nikz where did you manage to get another actuator...flip i cant find one anywhere so just did the external spring mod on mine and has been working 100% for the last 3 years.
Forge is life.
Bagged '12 Edition 35
Bagged '08 Polo Gti
IR Tuned
My CW PGTI
My CSG ED35
Killerwatt
Car Model: S3
Post by Killerwatt »
Hard to say from your description. I don't think its the actuator being weak.
Any logs of the car?
How does the requested boost, actual boost and n75 duty compare?
Is the actual load exceeding the specified load and the throttle closing?
Killerwatt
Car Model: S3
Also what are fuel trims sitting at? To check for a weak actuator, just unplug the n75 electrical connection and check that the boost is around 0.3bar under full throttle.
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
How much dollar :lol:
Darryn Van Rooyen
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
So much dollar I can't even say! :troll:
I need to keep this cab for the next year or 2 at least. Not having to pay installments is boss!
El Toro
Blossom
The Snail
Car Model: MK4 GTi
Post by The Snail »
Exactly what killerwatt said :iagree:
ex. Golf 4 GTi AGU/AUQ
t3/t4 50 trim .48ar
260kW and 390nm
Eurodyne maestro software
Audi 3.2 vr6 Turbo
323Kw and 660nm @ 0.7 bar
Nikz_tsc
Car Model: Mk7 GTi
Membership No: 2093
Post by Nikz_tsc »
Friend had a blown k03s which i pulled the actuator off. I think i still have it lying around though. Will look for it.
Current: Mk7 Gti
TSC Garage
0619955604
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
Yeah cos i know you cant really buy them new, ive tried looking
BMW 120D E87
Hobbs
Registered for: 11 years 11 months
Car Model: GTI MK5 - 248kw 530nm - KO4
Membership No: 1848
Post by Hobbs »
Ko3s love to surge with stock actuator, get a forge actuator and issue will be resolved.
Sent From my POS.
I.G - Hobbs_ZA
MK5 GTI
GTX30
Forged motor
power uknown
Killerwatt
Car Model: S3
How on earth will an actuator with a higher spring rate make a turbo less likely to surge?
Stompie, what's your actuator at now?
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
Killerwatt wrote:How on earth will an actuator with a higher spring rate make a turbo less likely to surge?
My actuator is set to two turns in as per what yosh told me to do cause it was opening up too soon.
BMW 120D E87
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
Hi guys, better later then never, issue got slightly worse and I could hear turbo flutter. Bypassed the n249 after doing some Vortex reading and everything returned to normal.
El Toro
Blossom
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Post by P1LAYA-ZN »
What should be the boost reading on the boost guage @ idle, mines is also around - 0.6 / 0.7 Bar ?
#Builtnotbought
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
P1LAYA-ZN wrote: Wed May 02, 2018 12:34 pm What should be the boost reading on the boost guage @ idle, mines is also around - 0.6 / 0.7 Bar ?
-0.7bar on idle -0.6bar should also be good.
BMW 120D E87
P1LAYA-ZN
Post by P1LAYA-ZN »
Cool, also how would you know there is a boost leak if you have a guage fitted ?
My S3 8L is stock and peaks @ 0.8Bar, but gradually drops and car feels lazy, although these cars are slow in stock form.
Should it peak @ 0.8Bar and stay there ?
What is the stock boost for this car, and when doing Software, what is the max safe level of boost for pump fuel ?
#Builtnotbought
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
To find a boost leak, you will need to pressurize the system.
0.8bar from what i remember is stock boost, Should peak at 0.8bar and taper off as revs climb.
Stage 2 software saw me hitting 1.4bar boost, thats usually the norm with a stock turbo and is safe. not sure if you can go higher.
BMW 120D E87
P1LAYA-ZN
Post by P1LAYA-ZN »
Thanks, just what I needed to know.
#Builtnotbought
