Polo GTI 9n3 Gearbox swap? video added pg2
- Neuk
- Treasurer
- Membership No: 806
Re: Polo GTI 9n3 Gearbox swap?
It's threads like this that make me remember Jaco Liebenberg, what a legend, taken too soon...
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
So apparently Mayfair gearbox has re-conned boxes for like R4800. Need to phone them and check if they got the exact gearbox or perhaps try going 02J as ive heard its a stronger box!
- Caddyon
- Car Model: Polo 9N3 1.9Tdi Sportline
- Membership No: 2025
TDI box...6 speed FTW
Tyrone - SR Tuned - http://www.facebook.com/srtuned
Current 06 9N3 Sportline - 1.9 BIG TURBO TDi SRTuned / Profiturbo.com
Power Figures 221wkw and 569wnm
Dezzi Drags = Boost + Diesel, no gas : 12.5
Current 2010 KTM 200 XC-W
Ex=Vw MkI Citi
Ex=Ford Ranger 2500Tdi 4x4 Supercab
Ex=Vw Caddyon 2.0 8v
Ex=2001 Vw Jetta 4 v5
Ex=2000 Opel Corsa GSI
Ex=1967 Ford Anglia 1600 Sport
Ex=1999 Opel Corsa Ute Chin Scraper
Ex=Vw MkI Citi
- Stompie
- Boostleak Guru
- Car Make: BMW
yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
Believe you me id like a 6 speed!
- Caddyon
ahhh ****...missionsStompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
Ex=Vw MkI Citi
Ex=Vw MkI Citi
- Neuk
- Treasurer
What are the gear ratio's like between the two gearboxes?Stompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
- Kyle
- General
- Car Make: Porsche
- Car Model: Adidas TYP 64
- Membership No: 1922
I doubt they'd match the revs of the engine since tdi = power down lowNeuk wrote:What are the gear ratio's like between the two gearboxes?Stompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
- Stompie
- Boostleak Guru
- Car Make: BMW
not sure, Probably a bit shorter with a long 6th gear.
Its probably the same as the 6 speed gearbox in the G4 GTI like Richards kar.
- Caddyon
All i found was thisNeuk wrote:What are the gear ratio's like between the two gearboxes?Stompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
TDI 6 speed
Top gear ratio 0.66:1
Final drive ratio 3.24:1
Ex=Vw MkI Citi
Ex=Vw MkI Citi
- Caddyon
And GTICaddyon wrote:All i found was thisGrumpy Catt wrote:What are the gear ratio's like between the two gearboxes?Stompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
TDI 6 speed
Top gear ratio 0.82:1
Final drvie ratio 3.65:1
Ex=Vw MkI Citi
Ex=Vw MkI Citi
- Kyle
- General
- Car Make: Porsche
6spd mk4 box?
- Caddyon
MK4 GTI 6 speed boxCaddyon wrote:And GTICaddyon wrote:All i found was thisGrumpy Catt wrote:What are the gear ratio's like between the two gearboxes?Stompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
TDI 6 speed
Top gear ratio 0.73:1
Final drvie ratio 3.94:1
Ex=Vw MkI Citi
Ex=Vw MkI Citi
- Stompie
- Boostleak Guru
- Car Make: BMW
let say i look at getting another Gearbox.
Is it the AUG 02J gearbox that is a straight fit except the mounting that needs modding?
- Neuk
- Treasurer
That is exactly where I was headed but then you mentioned low down power in a TDi and I began to cry Torque Kyle, torque...Kyle wrote:I doubt they'd match the revs of the engine since tdi = power down lowGrumpy Catt wrote:What are the gear ratio's like between the two gearboxes?Stompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
- Kyle
- General
- Car Make: Porsche
Neuk wrote:That is exactly where I was headed but then you mentioned low down power in a TDi and I began to cry Torque Kyle, torque...Kyle wrote:I doubt they'd match the revs of the engine since tdi = power down lowGrumpy Catt wrote:What are the gear ratio's like between the two gearboxes?Stompie wrote:yeah but that requires lots of modding as its longer and the chassis needs to be cut and other things.
- Stompie
- Boostleak Guru
- Car Make: BMW
A quick shitty video, cannot hear it 100%
https://www.youtube.com/watch?v=aCCRIcYI_6w
Noticed this morning that while the gearbox and engine is cold and i pull away hard then i dont get the same whine.
Seems that it only starts when the gearbox oil has warmed up and i give it a bit. This morning i drove to work like a granny and found that even almost at work it doesnt sound as bad as when i floor it at every robot from home to work and the gearbox takes some strain then it starts making the noise bad.
Im really starting to wonder if its the turbo or if its the gearbox...The turbo doesnt sound normal
The whine is so bad at times it sounds like ive got one massive supercharger under the hood!
- SoDub
- Chairman
- Car Make: Seat
- Car Model: Seat Ibiza Cupra 20VT
- Membership No: 1998
Re: Polo GTI 9n3 Gearbox swap? video added pg2
Same sound here only in 1st... Chucky? on the forum. Maybe ask him what the noise is!
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
El Toro
Blossom
jeez from what i could hear that sounds terrible!!
mines is silent so dont know whats up with u other guys gboxes!
i only had my gbox flushed once before as per bullitin for syncros then the syncros fixed as the flush didnt fix it. that was over 120k ago!
but Stompie for you my friend only one thing comes to mind when i think of you
u putting too much finger!
Lolz
its a term we charous like to use.
means u fiddle to much!
Lolz
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
- DangerBoy
- Car Model: Mk4 GTi
- Membership No: 2002
Its coil packs Renier... With a boost leak.....
Mine sounds similar...
- Stompie
- Boostleak Guru
- Car Make: BMW
Nah wont say i fiddle too much, since owning the car i have done an oil change on the gearbox twice.
I remember racing someone some time ago an January i think and as i hooked second i missed and scratched the gear badly and im thinking that it started from then on...Perhaps hurt something.
- Stompie
- Boostleak Guru
- Car Make: BMW
I wish that was the case! Ive been saying to my self this whole week i hope its rather turbo than gearbox!DangerBoy wrote:Its coil packs Renier... With a boost leak.....
In the video you cannot hear it properly, i have a recording of it where i put my phone at the passenger side foot well and then you can hear it, let me upload that quick
eish the sleepless nights when something is not fixed
i hate it!
i doubt u could have damaged something - i have done many a bad grinds especially when giving it over an uneven surface!
best bet - drop it off with Morne
i hate it!
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
- Stompie
- Boostleak Guru
- Car Make: BMW
Ok here is a recording.
You can hear it properly at 8seconds into the clip.
http://vocaroo.com/i/s1lTtNcs8dcK
Ignore the clipping as its me trying to hold the phone while driving.
Yesterday it was really bad, on the high way on my way home got it all the way to 4th gear and then 5th its gone but the turbo sounded different.
Whats the chances of the turbo making this noise?
- SoDub
- Chairman
- Car Make: Seat
I'm thinking turbo? My car has DP and you can hear that turbo spooling. Not as loud as that but its a fweeeeeeep sound. 1st and second you hear it more up until about 3000 rpm. If it was your box it should do it through the rev range.
El Toro
Blossom
El Toro
Blossom
- Stompie
- Boostleak Guru
- Car Make: BMW
If that is the case and its turbo then im actually glad as the gearbox is flippen expensive.VeeDubbed wrote:I'm thinking turbo? My car has DP and you can hear that turbo spooling. Not as loud as that but its a fweeeeeeep sound. 1st and second you hear it more up until about 3000 rpm. If it was your box it should do it through the rev range.
If i need turbo then ill just get K04-001 as a replacement because sadly i dont have cash for BT now.
There is a K04-001 for sale for R2k...
