Smoking Polo Gti
Smoking Polo Gti
Hi guys.. I have a 2008 Polo Gti 1.8T 20v.. Its got 93000km. Have it for a year now and its stock with just a downpipe and exhaust done on it. Ive noticed that my car is smoking whenever its left on idle like at a traffic light or if its just idling for more dan 5 min. As soon as i start to rev it or drive, it puffs out clouds of smoke but then stops smoking. It smells like its over fueling and i have spoken to mechanics and was told that the valve stem seals need to be replaced. Can anybody confirm that for me or is there multipe diagnosis for this problem? If it is valve stem seals, how do i go about replacing them. Car still has all its power but does have a bit of lag.. please help.
- pyro-zn
- Car Model: Golf 7R
- Membership No: 2072
Re: Smoking Polo Gti
Correct me if I am wrong here, but valve stem seals will emit smoke all the time and not on idle only.imizk wrote:Hi guys.. I have a 2008 Polo Gti 1.8T 20v.. Its got 93000km. Have it for a year now and its stock with just a downpipe and exhaust done on it. Ive noticed that my car is smoking whenever its left on idle like at a traffic light or if its just idling for more dan 5 min. As soon as i start to rev it or drive, it puffs out clouds of smoke but then stops smoking. It smells like its over fueling and i have spoken to mechanics and was told that the valve stem seals need to be replaced. Can anybody confirm that for me or is there multipe diagnosis for this problem? If it is valve stem seals, how do i go about replacing them. Car still has all its power but does have a bit of lag.. please help.
I believe this will be the seals on the Turbo. Do this:
1. Let your car warm up to the normal engine temp.
2. Park it on an incline, with the front facing down (face down a$$ up).
3. Wait a few minutes. If you see smoke like you just explained, then it is the seals.
Nothing too major, just replace them sooner rather than later as this means you're gonna lose oil quicker. And it is not healthy for the Turbo in the long run. Keep checking oil too.
Current: '17 Golf VII R
Ex: '12 TR Golf Vi GTi DSG ::: Revo3 - thread
Ex: '13 Polo 1.4 Comfortline ::: PanoRoof | JOM Bluelines | 17" A-Line Racers | 17" VW Boavista's by Borbet - thread
I did park on an incline before and it does smoke .. after a few quick revs it stops smoking but once I leave it to idle again, it smokes
- pyro-zn
Then it's the Turbo seals. But I may be wrong since I cannot see the issue. Let's see what the others say.imizk wrote:I did park on an incline before and it does smoke .. after a few quick revs it stops smoking but once I leave it to idle again, it smokes
In the mean time, just keep checking and topping up on oil.
Ok will do so.. thanx for your help
- ruler_70
- Colonel
- Car Model: Golf 7 GTI
As pyro-zn said, it's the turbo seals.
Very common problem on 9n3 PGTI's with downpipes.
The downpipe lets a lot more air flow through which lets the turbo spin a lot more freely and causes the turbo seals to wear prematurely.
A lot of threads on here of people with the same problem.
Current: 2018 Golf 7.5 GTI
Ex: 2016 Golf 7 GTI
Ex: 2014 Audi A3 Sportback 1.8T
Ex: 08 Silver Bird Polo GTI
Ex: 06 Polo 1.6i Comfortline
Ex: 98 Mk3 Golf GSX 1.8i
Ex: 2016 Golf 7 GTI
- MouseGTI
- Car Model: B8 2.0Diseasel
expensive to fix?ruler_70 wrote:As pyro-zn said, it's the turbo seals.
White '07 Polo GTI 9n3 - Stock
Black '07 Polo GTI 9n3 - 113fkw 234nm stock -> 153kw 277nm chooned
Silver '07 Slowdi A4 B7 1.8t - w/ T3T4 powers
Green '16 Kawasaki Z300 - 28kw
Blue '15 Yamaha MT-07 - 55kw
Blue '13 B8.5 A4 2.0TDI - 130kw
- ruler_70
- Colonel
That i'm not sure about, if it's through the agents i'm sure it will be though.MouseGTI wrote:expensive to fix?ruler_70 wrote:As pyro-zn said, it's the turbo seals.
Ex: 2016 Golf 7 GTI
Ex: 2016 Golf 7 GTI
- pyro-zn
ruler_70 wrote:That i'm not sure about, if it's through the agents i'm sure it will be though.MouseGTI wrote:expensive to fix?ruler_70 wrote:As pyro-zn said, it's the turbo seals.
Yes, the agents will take away your Christmas bonus ... till 2019. It can be sorted under Warranty.
Any idea what the smoke colour was?
- Registered for: 2 years 3 months
How do you replace the turbo seals. I went to a turbo repair shop in Maitland and they ask me R4500 to repair it. Is it something i can do myself.
The color of the smoke is white. It only smokes when it is idle, but when you drive the smoke slowly stops. I did replace my PCV and it did stop smoking, but after a few days, it started smoking again when it idle. When I took out the new PCV I felt oil in it as well as in my air pipes.
