Golf 5 GTI issues. Please Help
- Registered for: 20 years 7 months
- Car Model: MKV Gti
Hi guys , I need some assistance. Car in question Golf 5 GTI ( Mods: Revo stage 2,ITG Intake,DP and forge DV. Last week my car went into what I believe is a soft limp, happened while on an incline at wot around 4500rpm , felt like a miss and then the car felt as if it had no Turbo. Had the car scanned and logged (thanks to Shygolf for his time and patience) no errors but we noticed the following:
1.Timing pull on all cylinders from about 2000rpm ( between -8 and -11 degrees). From what I've read this is bad.
2.Fuel pressure drop from around 3000rpm to 4600rpm (requested pressure 110bar my pressure drops to 70bar). The pressure then increases back to 110 bar after 4600rpm.We checked the rear pump and this seems fine. Front pump seems to be the offending part here but not 100% sure.
3.Around 2700 rpm the wastegate starts to open, from comparing previous logs this does not seem to be normal.
Not sure where to start trouble shooting and hoping you guys can point me in the right direction. I have the logs but cannot post them up for some reason.
Any help will be highly appreciated.The above mentioned issues are really making me worried
- Solo786
- Car Make: Porsche,BMW,VW
- Membership No: 1251
Re: Golf 5 GTI issues. Please Help
whats your revo setting?
Did you check the cam follower on the hpfp
Solo786 wrote:whats your revo setting?
+1 ^ worn follower and or hpfp cam lobe or plunger worn (buy new pump or upgrade to Autotech). No low fuel pressure dtc's?
Also a bust coilpack <- wont always throw an error.
Worn follower with prolonged use makes this happen.
Thanks for the replies guys
@ solo - Setting B7 T3 F9. Cam follower has been checked normal wear and is replaced every 7000km, no scoring visible on the cam lobe.
@ Dale - Inspected the pump plunger all looks fine, never had a follower that failed. No errors regarding fuel pressure. Could coil packs on their way out cause timing pull ?
- dazza
- Car Make: VW and VW
- Membership No: 1327
When last did you change spark plugs?
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
Plugs changed approximately 5000km ago (Oem Plugs) , I have inspected them and they seem fine, all gapped to 0.75mmdazza wrote:When last did you change spark plugs?
- Car Model: White-G5 GTi
When I had SW (APR) on my car got similar symptoms while on holiday.
I was in Durban when it happen and Sameer from Experience Performance helped on a Sunday "Rave".
Car was fine on driving but on the Dyno started jerking. We changed Coils and ran test on Dyno again, no problem...Fitted old Coils and drove back to Jozi next day.
When I returned to Jozi I send car to VW and changed Coils to new. (Problem was solved!)
Also removed SW, car running on Stock file with HARDWARE upgrades (DP, Intake etc.)
Advise would be to check Coils .
I also had a cracked HPFP Sensor,..EASY Fix
hope you get sorted...SHOT
Thanks, I managed to get another fuel pump to try and see if that solves the fuel pressure issue. Going to replace the fuel filter as well and get some R8 coils.
Will update with results after this weekend.
Check Coils bro!
- Solo786
replace your follower anyway - the DLC is worn through.
Did you check the high pressure sensor?
Check plugs and coil packs as well
Agreee
coils and Sensor on HPFP,..take pic of sensor
If cracked I can fix it
Ok cool will replace the follower, awaiting R8 coils should have them by next week. Plugs seem fine but i have another set so will try them out. Inspected the sensor no cracks. Chatting to a buddy and he says that coils should throw an error if they were cooked , would bad coils pull timing ?
Thanks for the assistance guys really appreciate it
- Post Whore
- Membership No: 1343
If your fuel pressure is dropping that much and you're seeing that much timing pull it must relate to your lpfp or hpfp. There are other things not relating to your fuel pump that you can check like Maf, Map, Iat sensor on your intake manifold also inspect your intake manifold for leaks/cracks, throttle body, cam positioning sensor. What fuel are you using? If any of those sensors were faulty they would log an error, a faulty coil would misfire on a specific cylinder also logging a fault and the car would idle badly or make a tazer like sound on acceleration... your issue seems like a fuel pump related issue!
Lpfp is within spec, I suspect it's the hpfp. Fuel BP95 , when we scanned the car for errors nothing came up that's why I'm stunned at this issue. I will inspect the intake for crack etc, replacing the fuel pump today.
Thanks for the help once again.
- Solo786
it could be the internal seal on the hpfp thats shot and its losing pressure - but in that case it usually drops down and does not recover pressure
Okay a small update, I replaced the fuel pump and follower and the issue is still present need to log it again though but it the car still goes into limp mode under wot in high gear from 3000rpm and after a few km's of cruising its back to normal. Checked the intake for cracks and cannot find anything. What I did notice is that in all gears when driving the car hard from take off there is a “whistle “ from the intake around the same rpm where I'm having the issue. If I can recall this sound was never present previously. Could this possibly be a sign of a boost leak? and would a leak cause a drop in the fuel pressure ?
- Solo786
have you logged the boost pressure to check actual vs requested
and when you say your LPFP is within spec- what values are you seeing? It should not go below 4bar
Lpfp - pressure does not drop below 5.6bar. Logs for boost pressure below, sorry for posting like this.
Engine Speed Boost Pressure Boost Pressure
(specified) (actual)
/min mbar mbar
2880 2450 2190
2960 2470 2240
3040 2480 2270
3120 2480 2280
3200 2490 2280
3320 2490 2290
3400 2490 2300
3480 2490 2310
3600 2480 2310
3640 2470 2310
3720 2460 2310
3840 2440 2320
3960 2430 2300
4040 2420 2280
4080 2410 2270
4200 2410 2250
4280 2400 2210
4360 2400 2190
4440 2390 2160
4560 2370 2110
4600 2360 2100
4680 2340 2060
4800 2310 2060
4840 2290 2010
4920 2280 2000
5000 2250 1990
5080 2230 1980
5160 2200 1950
5240 2190 1940
5280 2170 1920
5400 2140 1900
5440 2130 1860
5520 2110 1850
5600 2090 1830
5640 2070 1820
5720 2050 1800
5760 2030 1790
5840 2020 1780
5880 2000 1760
5960 1980 1740
6000 1970 1720
6080 1950 1710
6120 1940 1690
6200 1930 1670
6240 1920 1650
6320 1900 1630
6360 1890 1630
6440 1890 1620
6480 1870 1600
6520 1870 1600
/min mbar mbar
2880 2450 2190
2960 2470 2240
3040 2480 2270
3120 2480 2280
3200 2490 2280
3320 2490 2290
3400 2490 2300
3480 2490 2310
3600 2480 2310
3640 2470 2310
3720 2460 2310
3840 2440 2320
3960 2430 2300
4040 2420 2280
4080 2410 2270
4200 2410 2250
4280 2400 2210
4360 2400 2190
4440 2390 2160
4560 2370 2110
4600 2360 2100
4680 2340 2060
4800 2310 2060
4840 2290 2010
4920 2280 2000
5000 2250 1990
5080 2230 1980
5160 2200 1950
5240 2190 1940
5280 2170 1920
5400 2140 1900
5440 2130 1860
5520 2110 1850
5600 2090 1830
5640 2070 1820
5720 2050 1800
5760 2030 1790
5840 2020 1780
5880 2000 1760
5960 1980 1740
6000 1970 1720
6080 1950 1710
6120 1940 1690
6200 1930 1670
6240 1920 1650
6320 1900 1630
6360 1890 1630
6440 1890 1620
6480 1870 1600
6520 1870 1600
- Solo786
well its clear that your actual is about 300mbar off request.
Log the wastegate duty cycle and you will also see its probably pegged at 99%..
boost leak somewhere
Thanks for all the assistance with regards to my issue I really appreicate all the help.
Wastegate duty cycle logs below.
Engine Speed Wastegate (N75)
Duty Cycle
/min %
1640 51.4
1640 99.6
1640 99.6
1640 99.6
1720 99.6
1760 99.6
1800 99.6
1840 99.6
1880 99.6
1920 99.6
1960 99.6
2000 99.6
2080 99.6
2120 99.6
2160 99.6
2240 99.6
2280 99.6
2360 99.6
2440 99.6
2480 99.6
2520 99.6
2600 99.6
2680 83.9
2760 82
2840 83.5
2920 82.7
3000 83.5
3080 83.5
3120 82.7
3240 83.1
3320 84.7
3360 83.9
3440 83.9
3560 85.9
3600 89.8
3680 90.6
3760 88.6
3840 87.8
3920 88.6
4000 91.4
4080 92.5
4160 94.9
4240 93.3
4320 96.1
4400 95.7
4480 96.1
4560 98.4
4600 97.3
4680 96.5
4760 96.1
4840 95.7
4920 94.9
4960 94.9
5040 94.9
5120 94.1
5200 94.9
5240 94.1
5320 92.5
5360 94.9
5440 94.9
5520 94.9
5560 94.9
5640 94.9
5680 94.9
5720 94.9
5800 94.9
5880 94.9
5920 94.9
5960 94.9
6040 94.9
6080 94.9
6120 94.9
6160 94.9
6240 94.9
6280 94.9
6320 94.9
Duty Cycle
/min %
1640 51.4
1640 99.6
1640 99.6
1640 99.6
1720 99.6
1760 99.6
1800 99.6
1840 99.6
1880 99.6
1920 99.6
1960 99.6
2000 99.6
2080 99.6
2120 99.6
2160 99.6
2240 99.6
2280 99.6
2360 99.6
2440 99.6
2480 99.6
2520 99.6
2600 99.6
2680 83.9
2760 82
2840 83.5
2920 82.7
3000 83.5
3080 83.5
3120 82.7
3240 83.1
3320 84.7
3360 83.9
3440 83.9
3560 85.9
3600 89.8
3680 90.6
3760 88.6
3840 87.8
3920 88.6
4000 91.4
4080 92.5
4160 94.9
4240 93.3
4320 96.1
4400 95.7
4480 96.1
4560 98.4
4600 97.3
4680 96.5
4760 96.1
4840 95.7
4920 94.9
4960 94.9
5040 94.9
5120 94.1
5200 94.9
5240 94.1
5320 92.5
5360 94.9
5440 94.9
5520 94.9
5560 94.9
5640 94.9
5680 94.9
5720 94.9
5800 94.9
5880 94.9
5920 94.9
5960 94.9
6040 94.9
6080 94.9
6120 94.9
6160 94.9
6240 94.9
6280 94.9
6320 94.9
- Solo786
from 4000 rpm the WG is closing to make boost.
If you check the car for boost leaks and you find none then its likely that your K03 is cracked in the exhaust housing and around the WG door and isnt making boost as it should.
It could just be the ecu pulling back the fuel pressure as a safeguard, as from you've mentioned thus far it doesnt seem like anything is a miss on the fuel side.. to be sure pull a log of the lambda values when you get a chance.
Turbo could be cracked, I've heard of this happening. Sorry should have posted all these logs at once.
Lambda Values below.
Engine Speed Lambda Sensor Lambda Sensor
Current Value Specified Value
/min
2880 0.73 0.73
2960 0.72 0.72
3040 0.72 0.72
3120 0.71 0.72
3200 0.7 0.72
3320 0.7 0.72
3400 0.71 0.73
3480 0.72 0.73
3600 0.73 0.73
3640 0.72 0.73
3720 0.73 0.73
3840 0.73 0.74
3960 0.73 0.74
4040 0.73 0.73
4080 0.73 0.73
4200 0.73 0.74
4280 0.73 0.75
4360 0.73 0.75
4440 0.74 0.75
4560 0.75 0.75
4600 0.74 0.75
4680 0.74 0.76
4800 0.75 0.77
4840 0.77 0.77
4920 0.77 0.77
5000 0.75 0.77
5080 0.76 0.77
5160 0.77 0.78
5240 0.78 0.78
5280 0.77 0.79
5400 0.77 0.79
5440 0.78 0.79
5520 0.77 0.79
5600 0.78 0.78
5640 0.77 0.77
5720 0.77 0.77
5760 0.76 0.77
5840 0.75 0.77
5880 0.74 0.76
5960 0.75 0.77
6000 0.75 0.76
6080 0.74 0.76
6120 0.75 0.76
6200 0.75 0.76
6240 0.75 0.76
6320 0.75 0.76
6360 0.75 0.75
6440 0.74 0.75
6480 0.74 0.76
6520 0.74 0.75
6520 0.65 0.75
/min
2880 0.73 0.73
2960 0.72 0.72
3040 0.72 0.72
3120 0.71 0.72
3200 0.7 0.72
3320 0.7 0.72
3400 0.71 0.73
3480 0.72 0.73
3600 0.73 0.73
3640 0.72 0.73
3720 0.73 0.73
3840 0.73 0.74
3960 0.73 0.74
4040 0.73 0.73
4080 0.73 0.73
4200 0.73 0.74
4280 0.73 0.75
4360 0.73 0.75
4440 0.74 0.75
4560 0.75 0.75
4600 0.74 0.75
4680 0.74 0.76
4800 0.75 0.77
4840 0.77 0.77
4920 0.77 0.77
5000 0.75 0.77
5080 0.76 0.77
5160 0.77 0.78
5240 0.78 0.78
5280 0.77 0.79
5400 0.77 0.79
5440 0.78 0.79
5520 0.77 0.79
5600 0.78 0.78
5640 0.77 0.77
5720 0.77 0.77
5760 0.76 0.77
5840 0.75 0.77
5880 0.74 0.76
5960 0.75 0.77
6000 0.75 0.76
6080 0.74 0.76
6120 0.75 0.76
6200 0.75 0.76
6240 0.75 0.76
6320 0.75 0.76
6360 0.75 0.75
6440 0.74 0.75
6480 0.74 0.76
6520 0.74 0.75
6520 0.65 0.75
- Solo786
Thats quite rich hey.. and you say revo settings are on F9?
whats your long term fuel trims at?
Any idea what the IDC is as well?
You have timing pull, and i thinks its dumping fuel..
lets see the LTFT
lets see the LTFT
