They make your engine bay look niceCurryboygp wrote:Please confirm what do these coil packs do.
is just better / stronger spark
R8 Coil Packs
- SHAUN
- Post Whore
- Car Make: BMW
- Car Model: 2006 335i
- Membership No: 1148
Re: R8 Coil Packs
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
- Registered for: 16 years
- Car Model: JETTA MK3
Re: R8 Coil Packs
so basically its not worth getting
2010 Audi A6 - 2.0Tfsi - Hers
2010 Bmw E90 Dynamic Edition 335i - Mine
Ex - 2010 Bmw E90 335i
Ex - 2011 E90 Bmw 320d Mpack - Mine
Ex - 2006 Vw Jetta Fsi 2.0 Turbo Dsg
Ex - Jetta 3 - Csx 2.0 - 8Valve - 101whp
Ex - 1992 Honda Dohc
Ex - Toyota Rxi 20V Turbo - 221whp at 0.4bar boost
Ex - E90 Bmw 325i
Ex 1997 Civic Vtec
Ex 2007 Run x Trd
Ex 1998 Citi Sonic 1.6
Ex - E90 Bmw 325i
Ex 1997 Civic Vtec
Ex 2007 Run x Trd
- Car Model: GOLF 4 CABRIOLET
- Membership No: 1841
Re: R8 Coil Packs
plastii-dip your old ones
"on the 8th day God created a HONDA, on the 9th day he traded it in on a VW"
- Post Whore
- Membership No: 1343
Re: R8 Coil Packs
Nope not really...oettingerA4 wrote:fk all...same for same as the black topsCurryboygp wrote:Please confirm what do these coil packs do.
stock coil packs - 3.3 ohms
rs3 coils - 4.5 ohms
R8 coils 5.7 ohms
- Titleists
- Philosopher STIG
- Car Model: 2016 Golf R
- Membership No: 1520
Re: R8 Coil Packs
Correct, it's like adding OB to a 1300 chico.Curryboygp wrote:so basically its not worth getting
- ryanrich
- Car Make: Ford
- Car Model: Territory
Re: R8 Coil Packs
It's very worth getting if your car came with crap coils, as mine did. 3 different guys I know with the same coils mine came with had them fail between 30 and 50k, that's why I changed mine for these updated ones, and I just chose the red ones because racecar.
http://www.golfmk6.com/forums/showthread.php?t=37818
2016 Ford Territory TDCi Titanium AWD
2016 Kia Sportage Si
- Porra46
- Car Model: Golf 6 R DSG
- Membership No: 1858
Re: R8 Coil Packs
The R and Ed35 have good coilpacks... Black tops with stainless steel shaft. They are pretty robust. The G6 has black tops with rubber shaft. They seem to perish quick. So the R8 coil is a good upgrade here. Just more durable...
2012 Candy White Golf 6 R DSG - APR Stage 3
460BHP/344Kw and 608Nm
11.9s 1/4 mile @ Tarlton - Dragwars 2015
- Belix
- Car Model: Passat B8
Re: R8 Coil Packs
But how do the GW ones compare to the OEM R8 ones?
- Porra46
Re: R8 Coil Packs
I dunno... I have the GW ones... Doubt they that much different to OEM... I also paid something like R1600 for them...Belix wrote:But how do the GW ones compare to the OEM R8 ones?
- Post Whore
Re: R8 Coil Packs
Buy an R8 in the UAE and remove its coilpacks then you tell me R8 coilpacks don't workTitleists wrote:Correct, it's like adding OB to a 1300 chico.Curryboygp wrote:so basically its not worth getting
Re: R8 Coil Packs
for the 1.8t guys with std turbo you wont make any more power - these coilpacks are just more reliable - if you running a BT you can see gains of up to 20whp with these coils if you run a larger gap on spark plug..
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
- pluto
- Registered for: 20 years 6 months
Re: R8 Coil Packs
Perhaps 20 whp going from shot plugs and coils to a good working set. I will believe this if its done here back to back on a dyno , new set to new set
To get a possible gain , its not that easy , you need to play with the dwell time's and that could toast your coils right away if you get it wrong.
Yes , its more reliable but its not a coil pack specific to the R8 , it's also the same as a4/s4/a5/s5/a6/s6 q3/5/7 Touareg
Shiver me Wastegates
Frieling Racing Chip tuning
Yashin@frc.co.za
082 805 9060
2013 TT-RS S Tronic
MK1 20VT BAM (Motronic ME 7.5 DBW)
Yashin@frc.co.za
082 805 9060
2013 TT-RS S Tronic
Re: R8 Coil Packs
Good Day
Can someone Please assist Me.
Need R8 Coils Perhaps the person to contact where I can get In the Pretoria Area.
Re: R8 Coil Packs
find your closest goldwagen
http://www.goldwagen.com/index.php/en/storelocator
- yeo786
- Car Model: Velociti 1.6i
Re: R8 Coil Packs
Sorry for a revival guys, but can I use these on a 60-2 Dicktator on abf with hall type sensor?
Just wondering because the MK4 Golf Coil pack I have in mind is notorious for packing up, as seen in the MK4's
I won't mind spending the extra for a coil pack that won't give me sheeet later on
If you're in control, you're not going fast enough!
Current :
VW Velociti 1.6i
Ex -Honda Ballade EF 160i 16V Dohc - Sold
Ex -VW Citi 2.0 8V Carb - Sold
Ex -CitiRox 1.4i - Stolen
Current :
VW Velociti 1.6i
Re: R8 Coil Packs
I Really don't understand what the hall type sensor has to do with anything as that is an input.
But yes you can let the dictator fire that coil.
- P1LAYA-ZN
- Car Make: Audi, VW and Toyota
- Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Re: R8 Coil Packs
The only difference I've noticed is the car runs alot smoother with the R8 coils and I've been told the big difference is when you running software, and start messing around with the plug gaps. Hopefully I will find that out soon.
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Re: R8 Coil Packs
R8 coils produce a stronger spark allowing you to run a larger spark plug gap under high boost, which supposedly results in a more complete and even flame front.
What most don't know is that the dwell maps need to be changed to accomodate the R8 coils properly. Stock coils need longer dwell times to produce a good strength spark, R8 coils don't and thus run shorter dwell times. By keeping the stock dwell map with R8s you end up overcharging them with no additional spark strength. Why you don't see more R8 coils popping is because they are more heat resistant than stock coils.
(My example is between 1.8T coils and TFSI coils)
Re: R8 Coil Packs
Good day all. Could someone please help me. I got some red top R8 coils from GW and just had a look how they would fit in a 16V tappet cover but seem to be too big. Should I just press harder or are there some modifications to be done?
Thanks in advance
Sent from my SM-N950F using Tapatalk
Thanks in advance
Re: R8 Coil Packs
They don't fit in a stock 16v tappet cover. Adaptors to be welded into the cover is needed. Speak to Wikus at goldwagen delarey
Re: R8 Coil Packs
Thanks alot panic wanted to be sure before i went and grinded the rubber sealerpanic-mechanic wrote:They don't fit in a stock 16v tappet cover. Adaptors to be welded into the cover is needed. Speak to Wikus at goldwagen delarey
