Battery and heat gauge light
Rowen8v
Registered for: 2 years 3 months
Post by Rowen8v »
Hi guys, I have a mk1 1.8 with 2.0 pistons, some head work and polo ecu. Car drives fine and all does overfuel a bit and gets little hot even tho I have no thermostat but only when driving stop and go. My main concern is whenever I give a little throttle my heat light and battery light starts to flicker even though it's not runnig hot or anything what could be the cause?
Howie-WP
Membership No: 2033
Re: Battery and heat gauge light
Post by Howie-WP »
Rowen8v wrote: Mon Nov 29, 2021 11:36 am Hi guys, I have a mk1 1.8 with 2.0 pistons, some head work and polo ecu. Car drives fine and all does overfuel a bit and gets little hot even tho I have no thermostat but only when driving stop and go. My main concern is whenever I give a little throttle my heat light and battery light starts to flicker even though it's not runnig hot or anything what could be the cause?
another one..... :bang: :crazy: Please fit a thermostat, they are there for a reason.
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
As Howie
Please refit the Thermostat because it is part of the engine.
Rowen8v
Post by Rowen8v »
Howie-WP wrote: Mon Nov 29, 2021 12:46 pm
Only removed the thermostat temporarily because the car gets hot really fast, as soon as the temp starts rising I can't stand and idle at traffic lights because the temp gauge goes just past normal operating temp and stay there until I start driving again, could removing the thermostat be the reason for those lights flickering?
n.gov3
Registered for: 6 years 11 months
Post by n.gov3 »
Rowen8v wrote: Mon Nov 29, 2021 8:18 pm
Seems like the thermostat is faulty.... Replace it with a new one and then check if the radiator fan works as it should.
EX-DOHCTOR
Membership No: 712
Post by EX-DOHCTOR »
Are you running coolant or just water?
What size radiator are you using? Stock?
What heat range is the radiator fan switch?
dcmk4
Registered for: 9 years 11 months
Car Model: MK7 GTi
Post by dcmk4 »
Did you replace the water pump or make sure it is even moving water? I won't be surprised if it is corroded away or broken.
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
Rowen8v
Post by Rowen8v »
Solved the problem, went through the whole cooling system and found that the bottom section of the radiator was clogged so bad that flushing couldn't get rid of, decided to get a new one and it's running fine now. Thanks for the help 👍🙏
JCTPUBLISHERS
Registered for: 3 years 8 months
Post by JCTPUBLISHERS »
Glad you sorted out.
