I changed gasket and took cylinder head for engineering but keeps pour water to oil section.
What can it be?
Sent from my M2006C3MG using Tapatalk
Oil Mixing with Water
Re: Oil Mixing with Water
Check
if correct gasket was fitted
Cylinder head bolts tighten to correct spec
Could be block is crack
You will have to perform a cylinder head leakage test
- Car Model: BM Trouble u
What car is it?
- Registered for: 2 years 8 months
Caddy max 1.9 TDI.JCTPUBLISHERS wrote:What car is it?
Thank you for your input.JCTPUBLISHERS wrote:Check
Also check the heat exchanger on the oil filter housing.
These are known for rusting through and causing oil and water to mix.
Sent from my M2101K6G using Tapatalk
