When a conversation to mp9 is done does the engine code change? 1.8 carb block with a fuel injected cylinder head. Golf mk1
Because the the engine code on papers and disk are the same but not infront on the block? Infront code says AFV and on disk it says HM. Which motor is AFV? Is that a code? And is the another on the block with the code? Cos many said its at the back on the block at the bottom.
Conversion
Re: Conversion
Hi guys just curious ... I drive a 14I mpi mk1 2008 mod ...ive heard that the mpi system does not take cams like if you want to change to a 272 they say it does not idle so I must go with dictator system .... I just wnated to put a cam and branch with freeflow so it can just sound better with a little more power not much but to spend all that money and do dictator or such not worth it then id rather sell the motor it has 80k on the clock ... soo I just wnat to know if I could cam a mpi motor?
