Engine code
Dawud
Registered for: 2 years 6 months
Engine code
Post by Dawud »
Hello, I would really like to know. Is the engine code infront of the block and if so The engine code on block is not the same as the one on the vehicles papers and license disk, how come?
Code on block starts with AFV and code on papers and disk start with HM or is there another code on the block? Many says its at the back of block but I came across that code AFV and wanted to know if that is the engine code AFV000817.
Vw golf mk1
Kyle28rsa
Car Make: volkwswagen
Car Model: MK1 1983 GLS
Re: Engine code
Post by Kyle28rsa »
Engine code is on the front of block. Code on the block and papers must correspond
Sent from my SM-G780G using Tapatalk
Kyle28rsa
Re: Engine code
Post by Kyle28rsa »
If the codes are different then the engine was swopped. So if you go for roadworthy you need to habe them register the new engine onto the papers
Dawud
Re: Engine code
Post by Dawud »
I bought the car second hand with that motor in it, i do have the papers of the vehicle however I don't have an ID copy of previous owner and I've lost contact with him. Is it possible to register the motor onto the papers of the vehicle without previous owners consent?
Kyle28rsa
Re: Engine code
Post by Kyle28rsa »
Dont think it would be an issue since you have the papers. You can give your nearest roadworthy station a call and explain the situation. They should be able to give a clear answer
Dawud
Re: Engine code
Post by Dawud »
And to get an engine clearance at the police station? Can j just give them the engine code or what is the procedure?
Car Make: VW, VW, Aprilia
Re: Engine code
Post by Jetta2 »
Long story short, you will need the original invoice for the engine, stating where it was bought and what the engine number is, then fill out an afidavit stating the motor was changed due to the original being busted, then they will go throught the whole process of checking the engine number to see if it is/was stolen, then you go to your nearest Metro police office and then you can get a new licence disc with the new engine numbe on it.
Dawud
Re: Engine code
Post by Dawud »
There is no invoice for the engine, only the papers of the vehicle and the owners registration details.
Does the block and cylinder head have codes of their own?
Owner said its a 1.8,on the license disk it says HM and on the papers it says HM. If a carburetor engine gets an mp9 conversion does the code change? Hence why I asked if the cylinder head has a different code to the actual block?
Greenz
Car Model: Focus ST
Re: Engine code
Post by Greenz »
Dawud wrote: Mon Sep 20, 2021 4:44 pm There is no invoice for the engine, only the papers of the vehicle and the owners registration details.
The number on the block is what is important.No,converting to fuel injection doesn't change the code on the licence disk.
2010 ST225 - 238kw 439nm
Dawud
Re: Engine code
Post by Dawud »
Where would the number be located on a carb block?
MacMan
Car Make: SEAT
Car Model: Tarraco XC 1.5 TSi
Membership No: 478
Re: Engine code
Post by MacMan »
HM = 1.6 carb
AFV = 1.8i
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
JCTPUBLISHERS
Registered for: 3 years 9 months
Re: Engine code
Post by JCTPUBLISHERS »
Do a RPC - Request for police clearance- not sure where you are for example JHB you take care to Langlaagte - line previous member told you your local road worthy centre will help you. Cross fingers engine is not stolen?
