Fitting a 2l oil pump in 1.6
buggyfan
Car Make: mk1
Car Model: GTX
Re: Fitting a 2l oil pump in 1.6
Post by buggyfan »
Kyle is this the same engine where the headgasket was put on wrong way round blocking the oilport to the head?
Kyle28rsa
Car Make: volkwswagen
Car Model: MK1 1983 GLS
Post by Kyle28rsa »
buggyfan wrote:Kyle is this the same engine where the headgasket was put on wrong way round blocking the oilport to the head?
Apologies. I didnt see this message. Its another motor. The one you talking about ran a slight bearing so i decided to take it out and rebuild it when i have time.
This motor thats in now is the same 1.6 EM that i bought as a rebuild. Suppose to be just put in and go but that was never the case and having endless issues. Im driving it as is with the low pressure. Will probably get a bearing knock in the future but i cant afford to have it standing.
Didn have a chance to check the oil pumps relief valve out but i doubt thats the case as I've tried 3 different pumps already
Sent from my SM-G780G using Tapatalk
buggyfan
Car Make: mk1
Car Model: GTX
Post by buggyfan »
I also had endless issues trying to diagnose low oil pressure. At the end of the day we found the cam saddle clearances were way out of spec.
Kyle28rsa
Post by Kyle28rsa »
Do you perhaps know what the clearance should be so i can check mine
buggyfan
Car Make: mk1
Car Model: GTX
Post by buggyfan »
Hi. All i could find is a max wear limit of 0.1mm.
Kyle28rsa
Post by Kyle28rsa »
So anything under 0.1mm is fine then as long as its torqued to spec
