Hi guys. Been years since iv posted something here.. needed the mk2 gurus thoughts on this
My 16v is an original kr model 1.8 16v
iv upgraded the gearbox to 02a type cable shift
Everything bolts up mounting wise but on careful inspection things look a bit odd. cv seems closer to subframe on the lft side ie. gbox side.
Am using all the kr engine mounting brackets and 02a (cable shift) gearbox mounting brackets from a late model mk2.
After some research it appears that i require a mk2 9a rear engine mounting bracket....?? (to push the motor fwd)
Do i require a 9a front mounting (starter) bracket too?? the kr and 9a look the same to me
Is the abf mk3 rear engine mounting bracket the same as a 9a mk2 mounting?
Is the hydraulic rear engine mounting 9a(on subframe) different to the solid kr (subframe) mounts?
Comments ....
Mk2 16v 02a mountings
Re: Mk2 16v 02a mountings
On a side note looks like the g60 mount brackets are the same as the 9a 16v
so i will require the rear engine mount bracket
and the front engine mount bracket
as they differ to the kr 16v type.
Anybody know where i can find this locally?
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
You can ask Goldwagen Delarey, they might be able to help.
Thanks. Iv spoken to them and they don't stock it or even fabricate it but awaiting a call back to see if they can still help me.
The mounting brackets I require are:
1. 357 199 273 Front starter mounting bracket
2. 357 199 354 or 535 199 354c Rear Engine mount bracket
If anybody has this for me to purchase or even to copy so I can fabricate it .
It comes oem on a 9a or g60 engine
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Also need the same mounts
Hope you find it
Hope you find it
Current : 2011 Audi A5 2.0TFSI
Current : 1988 VW Corrado
Ex : 1984 VW Jetta GLS 1.6 Automatic
Ex : 1990 VW Golf CSL 1.6
Ex : 2005 Audi A4 Avant(B7) 3.0TDI V6 Quattro
Ex : 2003 VW Golf GTI Executive
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
- marzbars
