Good Day guys
I have 2009 citi sport 1.4i airbag spec
The airbag light is on because we had to change the indicator/light switch as it was not illuminating brights.
thus the airbag was unplugged
now it is ilumunated on my dash.
how do i reset it so it don't show no more ?
Kind Regards
2009 citi sport 1.4i Airbag spec (how to reset the airbag light)
Re: 2009 citi sport 1.4i Airbag spec (how to reset the airbag light)
any help here guys
Do you have a OBD II Port?
As in the Polos and Golf/Jetta of that era, you have to clear the light through a diagnostic machine like VCDS, and only if the fault is fixed, as it will just come back then.
I would suggest getting someone to clear the codes for you using a diagnostic machine.
yes i do have a port
I dont have vcds
thought there is a code/sequence like with the service reset ? if there is any ?
There is no error or fault on the airbag , it was unplugged to change the indicator switch
Anyone use a program successfully with a elm327 diagnostic cable on VW cars?
Any1 willing to clear it for me in boksburg or edenvale area?
Thanks for reply guys
I dont have vcds
Rourke wrote: ↑Tue Dec 08, 2020 2:10 pm yes i do have a port
I dont have vcds
any body available ?
Check the VCDS registry under Technical discussions, Technical Motorvehicle related discussions, you will see there is a VAG COM / VCDS Register topic, find someone in your area from there.
Bigguuuup!!!! to Ryan
Nice meeting you bud
and i am glad the airbag warning light is off now
everybody enjoy your festive under the circumstances and stay safe
cheers
cheers
