shurlok A125-c ignition module change
- Registered for: 3 years 5 months
hi all need help with a shurlok ignition module..citi golf 1.4 2003 after testing it seems to be this shurlok A125-c ignition module is faulty and not providing spark on the 2 point coil. disi is working and coil. key is programed and working fine. i did try a standard tp100 module and a tp900b and failed. it seems that the module is coded to the key. my question is can i get this module from goldwagen and do i need to recode the key. or is a complete system modification needed "change to a different ignition system" please help me fix this issue
