Hi people
Please help me out...
I have a 2004 Audi A4 B6 2.0 (ALT Non-Turbo).
HISTORY:
Just before lockdown the car suffered a timing belt snap and bent almost all the valves.
Needless to say I had all 20 valves replaced, and all new valve guides, valve stem seals replaced, head bolts, etc.
Also new complete gaskets for the intake and exhaust, VVT solenoid, cam seals, and head gasket.
New timing belt kit (INA solid type) and new water pump and full service kit (Oil, spark plugs, air filter, fuel filter, oil filter).
PROBLEMS:
The car has almost no Torque & Power below 3000 rpm (I assume that is when the VVT comes into play). However, the car could barely maintain speed, Even @ 120km/h in 3rd gear. To put it in simple terms the car feels gutless
I had the car scanned and it picked up an error code Cam Position Sensor - signal too low (16725) to which I replaced the sensor and the car had the same problem.
Thereafter I had the car scanned again and the error code Cam Position Sensor - signal too High (16727) appeared.
After some research I discovered that the only remaining fault can be timing, So I redid the entire timing belt procedure from start to finish, including giving the cam gear timing a once over.
Took the car for a test drive and it's A LOT better, but the lack of power is still there, intermittently though. I was able to get the car to 150km/h. Still required a lot of downshifts though .
Please help me figure out why there is a Loss of Power and why it is intermittently.
All pics of timing marks can be seen in the pics below: Hopefully I didn't screw anything up
Exhaust Cam Gear Mark
Intake Cam Gear Mark
Crank Pulley Mark
Cam Pulley Mark in relation to Tappet Cover
Dampener Pulley Mark
Also Note that everything about this car is stock and has 210 000 kms on the clock. It has seen regular services from new by the dealerships and since the end of the motor plan it has been serviced using Shell ultra oils and quality known parts sold only by Goldwagen.
Only parts ever replaced beyond service required parts are:
1. Thermostat unit
2. Accessory belt tensioner
NEED HELP PLEASE!!! - Audi A4 B6 - SLUGGISH
- Registered for: 8 years
- Car Model: '90 1.8 Caddy sport
- Membership No: 3224
Daily:
04 Audi A4 2.0 (B6)
90 VW Caddy 1.8 Sport
04 Audi A4 2.0 (B6)
Re: NEED HELP PLEASE!!! - Audi A4 B6 - SLUGGISH
Take it to Panic's place. He's in Benoni. He should have it sorted in a jiffy.
