Oil pump change
- Kyle28rsa
- Car Make: volkwswagen
- Car Model: MK1 1983 GLS
Oil pump change
Hey guys. I have a mk1 1.6 carb motor. Oil light was flashing so i checked and came accross that my head is receiving minimal oil if not any. Checked oil ports on head and by the switch everything seams clear. Only option i can think is the oil pump gave in. I have another oem oil pump from a 2l8v
So the question is will this oil pump be a direct fit and is there a difference in oil pressure that the 2l pump kicks out?
Re: Oil pump change
No difference in pressures. That is determined by oil clearances of the engine.
The pump is a straight fit as long as you have the newer rectangular style sump.
If your oil light was buzzing it usually means you are busy hurting the bearings on the crank. My suggestion is to pull the motor and do it up. Just putting a pump in may not solve the oil pressure problem.
- Kyle28rsa
Re: Oil pump change
I fitted the pump earlier and started it up. It popped the filters o ring and oil shot to the ceiling. Pulled the filter and positioned the rubber back thinking i maybe did not make it to tight. Happened again. Took it out the pump and fitted the old one back. Rubber didnt pop this time but still no circulation to the head
- Kyle28rsa
Re: Oil pump change
Think i should add that i replaced the head gasket. Ever since i put the head back on its been giving this issue. Getting tappet sounds after a few seconds of starting. Its a shim head so i checked the valve clearence already just incase. Everything seems in order. I fed a wire through all the oil ports on the head including the side
- chucker02
- Car Model: Citi ADY
Re: Oil pump change
The 2L pump is not a direct fit into a 1.6. The shaft is longer so you cannot use it
1971 VW beetle
1971 VW beetle
Re: Oil pump change
Did you use the correct head gasket?Kyle28rsa wrote: ↑Sun Sep 13, 2020 7:27 pm Think i should add that i replaced the head gasket. Ever since i put the head back on its been giving this issue. Getting tappet sounds after a few seconds of starting. Its a shim head so i checked the valve clearence already just incase. Everything seems in order. I fed a wire through all the oil ports on the head including the side
Gasket fitted correctly?
Issue coming up after head gasket replacement, is probably a clue
- Kyle28rsa
Re: Oil pump change
I took my old gasket with when i purchased the new one. All the holes matched and didnt look any thickern.gov3 wrote:Did you use the correct head gasket?Kyle28rsa wrote: ↑Sun Sep 13, 2020 7:27 pm Think i should add that i replaced the head gasket. Ever since i put the head back on its been giving this issue. Getting tappet sounds after a few seconds of starting. Its a shim head so i checked the valve clearence already just incase. Everything seems in order. I fed a wire through all the oil ports on the head including the side
- Kyle28rsa
Re: Oil pump change
According to another older post i saw on the group the shafts are a the same length. I measured it before putting it in just to make sure. Only difference is that the gear inside is bigger on the 2l pump. According to the postchucker02 wrote:The 2L pump is not a direct fit into a 1.6. The shaft is longer so you cannot use it
- Kyle28rsa
Re: Oil pump change
You may have installed the gasket upside down. This is very likely.
If this is actually the case it's also why your oil filter is popping off as the oil pressure is sky high in the block and no oil is passing to the head, the oil passage from the feed is closed off most of the way.
The gasket is fully reversible, the only difference is the direction of the oil feed line hole in the gasket. The block side is centred between cyl 2 and 3, whereas the head side is 10mm off to the side. The opening in the gasket is what joins these two passages.
Seems it's time to go back in order to make progress.
Also hopefully there isn't any damage to the cam and the head from oil starvation. Check for score marks on the cam caps and on the cam lobes.
- Kyle28rsa
Re: Oil pump change
I was very careful when putting on the gasket. I made 100% sure that i was not misaligning any of the holes. But if this is the only reason as to why the filter o ring is popping off then i guess i have no choice but to remove the head again.missioner wrote:You may have installed the gasket upside down. This is very likely.
Is there any way i can check if this is the case before removing the head. Maybe by any of the oil ports?
Made sure i lubed up the cam before starting and haven't seen any scorce marks
Re: Oil pump change
Get a cheap mechanical oil pressure gauge and fit it to the side of the head where the oil pressure switch goes. Newer models have a small Allen cap plug instead. It's just above the water port.
- Kyle28rsa
Re: Oil pump change
Thanks will purchase one and test the pressuremissioner wrote:Get a cheap mechanical oil pressure gauge and fit it to the side of the head where the oil pressure switch goes. Newer models have a small Allen cap plug instead. It's just above the water port.
- Car Make: mk1
- Car Model: GTX
Re: Oil pump change
We had the same issue with lack of oil to the head. Found a pieve of gunk blocking the oil passge from the block up to the head. Removed the head bolt inbetween number 3 and 4 cylinder and turned the oilpump with a drill with a modified bolt to clear the blockage.
- Kyle28rsa
Re: Oil pump change
Have you removed the head bolt just to get access to the oil pump to spin?buggyfan wrote:We had the same issue with lack of oil to the head. Found a pieve of gunk blocking the oil passge from the block up to the head. Removed the head bolt inbetween number 3 and 4 cylinder and turned the oilpump with a drill with a modified bolt to clear the blockage.
- Car Make: mk1
- Car Model: GTX
Re: Oil pump change
No we removed the distributor and spinned the oilpump by cutting a slot into a bolt and turning it with the drill.
Your oil supply channel goes out of your block alongside your one headbolt and angles into the head channels
- Kyle28rsa
Re: Oil pump change
Ok that makes sense. Just to be 100% certain. Which head bolt was move to be exactbuggyfan wrote:No we removed the distributor and spinned the oilpump by cutting a slot into a bolt and turning it with the drill.
- Car Make: mk1
- Car Model: GTX
Re: Oil pump change
The bolt on the waterport side /sparkplug side
- Kyle28rsa
Re: Oil pump change
Thanks buggy. Will try that method tomorrow.
- Kyle28rsa
Re: Oil pump change
Tried the method buggy. Removed the head bolt. Made a bit to spin the oil pump with a head bolt. Removed the dizzy and spinned the oil pump. I feel the drill struggle abit when spinning is and i can hear a sound in the head that sounds like compression which is closer to cylinder 1 side. Still no luck with getting the oil to shoot through
- Kyle28rsa
Re: Oil pump change
Would it help if i blow with a compressor into the oil switch
- Car Make: mk1
- Car Model: GTX
Re: Oil pump change
Did you spin the drill clockwise and anti clockwise?
Because if you turn the pump the wrong way you will get a gurgling sound coming out of the engine.
- Kyle28rsa
Re: Oil pump change
Spinned it clockwise. Should i do both directionsbuggyfan wrote:Did you spin the drill clockwise and anti clockwise?
Re: Oil pump change
Silly question..... did you prime the oil pump first by either pouring oil into it and turning it or by putting it in a container with oil and turning it before fitting it?
It has happened when unprimed oil pumps simply do not pump any oil because they were not primed before fitting.
- Kyle28rsa
Re: Oil pump change
Yes i have. Did it with all the oil pumps i tested to see if the pump was the issueJetta2 wrote:Silly question..... did you prime the oil pump first by either pouring oil into it and turning it or by putting it in a container with oil and turning it before fitting it?
