Spark issues
- Kyle28rsa
- Car Make: volkwswagen
- Car Model: MK1 1983 GLS
Spark issues
Good day
I have a golf 1 gti with the original dx motor. Im having issues with the spark. When i swing the motor, spark comes for about a second then cuts off completely until i swing the motor again and then the process continues. Any idea what the issue could be. I changed the following parts already: ignition coil, module, plugs leads and rotor cap
Re: Spark issues
Good day did you change the rotor as well??Kyle28rsa wrote:Good day
- Kyle28rsa
Re: Spark issues
I am yet to change the rotor. But if the rotor is the issue, shouldn't it atleast make contact once every revolution instead of just dying out completely
Re: Spark issues
Yes logically it should but you never know with electronics, sometimes it's a simple problem, how are you checking the spark??Kyle28rsa wrote:I am yet to change the rotor. But if the rotor is the issue, shouldn't it atleast make contact once every revolution instead of just dying out completely
- Kyle28rsa
Re: Spark issues
I checked with each of the leads going to the plugs by putting it against the motor. I tested the main lead coming from the coil as well giving the same issue
Re: Spark issues
Looks more complicated than it seems, I guess you've done all you can I guess you will have to consult with an auto electrician they deal with things like this every day....Kyle28rsa wrote:I checked with each of the leads going to the plugs by putting it against the motor. I tested the main lead coming from the coil as well giving the same issue
Re: Spark issues
What happened in the very beginning when this problem started, did the car cut out while driving or did it just not start at all one day, sometimes it's good to try and see when it all began.....mellos wrote:Looks more complicated than it seems, I guess you've done all you can I guess you will have to consult with an auto electrician they deal with things like this every day....Kyle28rsa wrote:I checked with each of the leads going to the plugs by putting it against the motor. I tested the main lead coming from the coil as well giving the same issue
- Kyle28rsa
Re: Spark issues
I was busy sorting out all the wiring in my car. Taking out whats not needed, making things tidy, etc. Then it just suddenly happened the next day. I did move the fuse box in its original place. Maybe i unplugged something. Any idea if any part of the ignition system goes to the fuse box or to any relays?
Re: Spark issues
Sorry I'm no expert you will have to just wait and see if anyone else respondsKyle28rsa wrote:I was busy sorting out all the wiring in my car. Taking out whats not needed, making things tidy, etc. Then it just suddenly happened the next day. I did move the fuse box in its original place. Maybe i unplugged something. Any idea if any part of the ignition system goes to the fuse box or to any relays?
- Kyle28rsa
Re: Spark issues
Thank for the help thoughmellos wrote:Sorry I'm no expert you will have to just wait and see if anyone else respondsKyle28rsa wrote:I was busy sorting out all the wiring in my car. Taking out whats not needed, making things tidy, etc. Then it just suddenly happened the next day. I did move the fuse box in its original place. Maybe i unplugged something. Any idea if any part of the ignition system goes to the fuse box or to any relays?
Re: Spark issues
No problemKyle28rsa wrote:Thank for the help thoughmellos wrote:Sorry I'm no expert you will have to just wait and see if anyone else respondsKyle28rsa wrote:I was busy sorting out all the wiring in my car. Taking out whats not needed, making things tidy, etc. Then it just suddenly happened the next day. I did move the fuse box in its original place. Maybe i unplugged something. Any idea if any part of the ignition system goes to the fuse box or to any relays?
