Hi
Just a quick question, has anyone with a polo vivo who has a starting problem when it is hot ever solved the problem by fitting a new coolant temperature sensor, I have a strong feeling that we are looking at the wrong component to solve the starting problem
Coolant temperature sensor.
Re: Coolant temperature sensor.
Then why don't you say what you think the correct component is that solves the problem.........
I don't know what the correct one is but VCDS says coolant temperature sensor intermittent fault, replaced it twice now even checked the wiring to it but problem still persistsJetta2 wrote:Then why don't you say what you think the correct component is that solves the problem.........
- Registered for: 4 years 4 months
- Car Model: Citi storm
Do you perhaps have a full description of the fault code or more info on exactly what the car is doing?
Sent from my SM-G965F using Tapatalk
Coolant temperature sensor intermittent fault, the car battles to start in hot weather whether the car temperature is cold /hotAspire_motorsport wrote:Do you perhaps have a full description of the fault code or more info on exactly what the car is doing?
When it stays in the sun for too long then it takes a while to start
Yes do you have the same problem?Ishaam wrote:When it stays in the sun for too long then it takes a while to start
MY 2009 VW City Golf 14i experience problems to a cold start. When switching on, it starts immediately and the revs are fine. Once you press the petrol pedal, the revs drop. The car miss and has no power. When it is warmed-up no problems are experienced.
Where is the Coolant temperature sensor situated. Should I replace it with a genuine part or after market suppliers. I resides in Pretoria.
Dewald
Dewald
- Registered for: 2 years 3 months
