Hi there
My 93 vw citi golf 1.8 sport had a bearing knock, it was a horrible sound and it was my first time experiencing such engine failure. The engine is not seized, but I couldnt get the car to start, it won't turn itself over. I opened up the sump and I found a big end bearing and a bent bolt that secures the big end. From looking underneath its visible that the block also has some damage. I'm expecting some others parts in the engine is also damaged. The options I have is to rebuild the engine or buy a second hand engine. If anyone would be kind enough to point me in the right direction, it would be very much appreciated.
Cape town
Engine rebuild or second hand engine
Re: Engine rebuild or second hand engine
Check goldwagen.
Iv seen them advertise brand new oem sub units and heads quite cheap too.
- Registered for: 19 years 5 months
- Car Model: Touareg / Caddy / Polo / Citi
I saw it in a Goldwagen brochure a month or two ago.
Perhaps get a quote from a reputable shop to rebuild, which you can then compare to the prices at GW. Remember to factor in things as getting the new engine registered on ENatis.
Anton van Graan
2009 Touareg 3.6 VR6
2007 Caddy Life 1.9 TDi
2004 Polo 1.6 Comfortline
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
1988 Ford Laser 1600i Sport
2000 Jetta 4 TDi
1997 Chico 1.3
2003 Audi S4
1999 Uno Turbo
1993 Uno Turbo
- ICE King
A proper rebuild is always the better option as a second hand engine is a risk.
Rebuild will cost more between the two in this case.
but....Your head could very well be fine still and maybe just need bottom repairs
I would strip first and then make a call
proper rebuild will run to like R14-16K these days.
- Car Model: MK1 1.4I
What sort of damage do you think the block has? Also damage where
unlikely that the block will have damage
- Car Make: Vw, Bmw, Merc
- Car Model: 81 Vw Mk1 Cabrio,15 Mk7GTi
- Membership No: 3258
Try the Goldwagen option for a new motor, also saw that add , and rebuilding a expensive now adays
