Hi, please help (advice) I'm running a Mp9 I've just done an engine overhaul a week ago, just this week l start having idleling problems, on ignition it has a normal high rev but it degrees quickly even on an could start, from then on it idle raff and go up and down below one on the rev count clock and die, I've clean the throttle body now I don't know what could be a problem please (help) advice
William Darck's Thusi
Mp9 idleling problem
- Car Model: Microbus
Re: Mp9 idleling problem
Howzit, could be a faulty map sensor. Check if it's plugged in properly or replace.
MK1 2.0 16v, Mk5 2.0 GTi, Kia Cerato Hatch 2011 2.0
- Car Model: Golf 1
Sounds like you need to do a throttle body adaption through VCDS system.Madalathusi wrote: ↑Sat Aug 17, 2019 6:23 pm Hi, please help (advice) I'm running a Mp9 I've just done an engine overhaul a week ago, just this week l start having idleling problems, on ignition it has a normal high rev but it degrees quickly even on an could start, from then on it idle raff and go up and down below one on the rev count clock and die, I've clean the throttle body now I don't know what could be a problem please (help) advice
