Hi guys,
I drive a 2010 "polo 6", problem is my car is misfiring, and taking out black smoke from the exhaust
I changed injectors, checked coil packs, changed map sensor, trottle body, oxygen sensor, but stil the problem is still ther.
Any 1 has an idea of what be the problem?
Your help will be highley appreciated
Car misfiring and black smoke from the exhaust
- Car Model: Mk5 gti
Re: Car misfiring and black smoke from the exhaust
Did u change plugs ? Check coil pack clips and wiring ?
Y dont u scan the car on vcds it will tell u exactly where the fault lies ...tell us ur location so we can reccomend u to some1
viewtopic.php?f=11&t=217296
Previous :too many to list
I did take for a scan just says misfire on cylinders, and yes i did change the plugs, coil pack clips n wiring wer checked still the same problem
Hi how did you check the coil packs? If you say a scan was done it should tell you which cylinder the misfire is on.Vee polo 6 wrote:Hi guys,
- DotDubb
- Can I buy your wheels?
- Car Make: Audi A6 3.0T
- Car Model: DKW, Cabrio, A6 avant,Mk2
- Membership No: 1593
If you can identify which cylinder has the misfire, then you can swop some coil packs over to see if the problem is in fact coil pack related.
1991 Golf Mk2 1.8 20vT
1960 Autounion DKW 1000s
+1DotDubb wrote:If you can identify which cylinder has the misfire, then you can swop some coil packs over to see if the problem is in fact coil pack related.
