Caddy back brakes binding
Warm caddy
Registered for: 5 years 1 month
Car Model: Polo vivo
Post by Warm caddy »
Can i have some help please
I replaced my back caddy bakkie back shoes, bought ATE brand, its drum shoes, my brakes keeps binding more like it doesnt release,
Brakes was put in exactly i took the old ones out, also bleed all brake lines after replacement
Vw Polo Vivo 1.4
Re: Caddy back brakes binding
You either installed something incorectly or simply pulled the adjuster too far down. When you put them in new you have to put the adjuster wedge all the way at the top at it's thinnest section.
Warm caddy
The adjust was at the fullest top, when assemble the disk turns freely the moment you start stepping on the brakes or handbrake it start binding, i was thinking maybe the hand brake lever at the shoes does not release at its fullest, the lever where the cable attach to
Vw Polo Vivo 1.4
Possibly you installed something wrong.
Warm caddy
Thanks Panic
Will check this weekend and revert back
Vw Polo Vivo 1.4
Warm caddy
Any good place where i can take the bakkie to check my braking out, if i cant get it fixed this weekend
In roodepoort, krugersdorp area
Vw Polo Vivo 1.4
Go visit wikus at delarey goldwgen. he probably knows those backwards.
Warm caddy
Thanks Panic,
Vw Polo Vivo 1.4
Warm caddy
So i took the car to a place in roodepoort the engin man, apparently the linings were not right and some springs, brakes is much beter but still abit of binding when cold but for a very short period then its fine
Vw Polo Vivo 1.4
ICE King
Post by ICE King »
If adjuster is set correctly , check if the hand brake needs adjusting.
The handbrake needs at least 3-4 "clicks" before fully braking - anything less will cause binding.
If not then check if your hand brake cables (underneath the car) that they are not bulging and running incorrectly.
Warm caddy
Hand brake cables seems fine what is strange is that this only happens when cold after a km of running it seems to getting loose and starts running freely
Hand brake takes fully around 5 clicks
Vw Polo Vivo 1.4
Warm caddy
It seems like brake linings were to thick, now after few days the brakes are loose and freely,
Thanks for all the advice
Vw Polo Vivo 1.4
ICE King
Post by ICE King »
Sounds correct! glad you sorted
Forgot that those shoes are relined.
Warm caddy
Thanks guys for the help
Vw Polo Vivo 1.4
