Fi conversion
UDC
Registered for: 17 years 2 months
Membership No: 1041
Re: Fi conversion
Post by UDC »
OBDII plug Pin no. - Ecu Pin No.
4 - Earth Pin no. 23
16 - 12v Pin no.21
7 - Pin No.29
Do you have the OBDII plug, its 3 wires, 2 is power and the 3rd is the communication wire to the mp9 Ecu
You will need the Vag software to check for faults etc.
Evin
Registered for: 6 years 4 months
Re: Fi conversion
Post by Evin »
Thanx UDC
Yes I do have the got it from a mk3 jetta, I have connected pin16 & 4 so there is power, but not to pins you mentioned. Use a 12v line and connected with a fuse(safety).
I notice there is grey/white on the loom same pin 7 on the port. Is that the one.
So this will work on my short loom (plug and play)
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
long as it was a power it will be fine, then you just need to connect pin7 of the OBDII plug to pin 29 of the Ecu
Evin
Re: Fi conversion
Post by Evin »
Thanx UDC
I will connect it tonight, ordered the vag cable so I only check it when i receive the cable
will give feed back
Evin
Re: Fi conversion
Post by Evin »
Finally got the port to communicate
Connected the pin7 to pin 29 last night
And today received my vag com cable, installed it and works perfectly
Scan my car and my parents car
Thanx UDC
Evin
Re: Fi conversion
Post by Evin »
Yes guys
Any one that help me with this
01250- Feul injector for Cylinder 2 (N31)
30-10 Open or short to Plus- Intermittent
Car is missing and than come right again, had the same problems about 2 months ago,
But now I can check with the scanner what wrong
Last time I had clean the injectors, but this can't be because I don't drive into reserve tank
Evin
Re: Fi conversion
Post by Evin »
Yes guys
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
Evin wrote: Wed Aug 12, 2020 7:35 pm Yes guys
What vehicle is that fault code for, the fault seems more like a wiring or faulty injector issue....try swapping the injector to another cylinder and see if the fault moves to that cylinder as well
Evin
Re: Fi conversion
Post by Evin »
Its a conversion on mk2 golf.
Had the same issue about 2 months ago where I just cleaned the injectors and drove fine until now, now that have OBD port install I get check what is wrong.
Can be dirty injector again
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
Evin wrote: Thu Aug 13, 2020 6:12 am Its a conversion on mk2 golf.
dirty injector wont throw a fault code
Evin
Re: Fi conversion
Post by Evin »
I'll check tonight again, drove to work this morning same thing, and need drive at a nice speed to get rid of the car missing
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
swap the injector to another cylinder, if the fault moves to that cylinder then you know for sure its the injector itself that is faulty and not a wiring issue.
Evin
Re: Fi conversion
Post by Evin »
Thanks will check tonight
Evin
Re: Fi conversion
Post by Evin »
So I checked it today swap the injector plugs around, injector plug two to injector one, code showed than on injector one. But car is driving fine, cleared the codes and disconnected the battery as well,
Run the scan again and no faults of that kind found
Car is driving fine now hoping it stays that way
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
Evin wrote: Fri Aug 14, 2020 7:49 pm So I checked it today swap the injector plugs around, injector plug two to injector one, code showed than on injector one. But car is driving fine, cleared the codes and disconnected the battery as well,
not the most ideal solution....I meant to swap the actual injector, not the wiring plug...mp9 supposed to fire the injectors in sequential pattern but this is not the first time where I have seen them all spray together hence your car is running fine.
Evin
Re: Fi conversion
Post by Evin »
Thnx will check later today, that was only solution that work yesterday to get me home from work
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
Is that the original ecu or was it remapped
Evin
Re: Fi conversion
Post by Evin »
I believe so, got the ecu from my uncle its a open box
Evin
Re: Fi conversion
Post by Evin »
HI UDC
so tried everything now, Saturday it magically came, until last night, Im gatvaol now, had no pleasure since the conversion
what i pick up, is that that power, on injector plug goes away, plug 2 (red & green/black) and that the problem since the beginning,
I'm not sure what can cause this, any solutions, my injectors is fine
thanx
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
Evin wrote: Wed Aug 19, 2020 8:00 am HI UDC
thanx
check the wiring on injector 2, might be a break in the wire...which is what the fault code states as well
whereabout are you based
Evin
Re: Fi conversion
Post by Evin »
Will check,
Yor im based In Hermanus area (Stanford) and here is actualy guys that knows much about mp9
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
Evin wrote: Wed Aug 19, 2020 9:42 am Will check,
speak to Alan from Hout Bay - +27 83 442 1122
Evin
Re: Fi conversion
Post by Evin »
Thanx will whatsapp him
Evin
Re: Fi conversion
Post by Evin »
I phone him, he also mentioned that it might something wrong with the wiring
whats confusing it suddenly goes away than everything fine and than i can drive for a few weeks, and than again the same problem
UDC
Membership No: 1041
Re: Fi conversion
Post by UDC »
either wiring or that no.2 injector is faulty....mp9 injectors are cheap, get a 2nd hand set change it and see what the car behaves....if you swapped the injector wiring and the fault still shows a short on no.2 cylinder...then its that injector that is faulty
