Evening all.
Got a buddy with a 1998 Polo classis. 1.8 MP9.
Car was running fine until it refuses to idle one morning.
Immediatly thought it was the Temp sensor so replaced it but still wouldnt idle.
Unplugged the MAP sensor, car would idle so assumed it was MAP sensor. We replaced it and still the same issue.
Car will not idle by itself.
We have checked for air leaks, broken wiring, replaced sparks plugs, checked rotor and cap and also replaced the coil.
Could it be TPS or FPR?
What else can you recommend we check?
Thanks in advance.
Polo 6N 1.8 MP9 wont idle.
- GolfGTI
- Car Model: 83 MK1 GTi
The MK1 GTi - MK1 Gti 1.8i - Under Construction
The MK2 GTi - Under Construction
The MK3 GSi - MK3 GS 2.0i - Sold
The Work Car - Chev 1.4 UTE
Re: Polo 6N 1.8 MP9 wont idle.
Swop the throttle body. Do a calibration.
- GolfGTI
Hi PM. Thanks for the reply.
How does one calibrate the TB? With VAGCOM?
Yes.
- ICE King
I would first try cleaning on the inside of the throttle body.
That almost never ends well. I know of more dead tb's from being cleaned than I know that benefitted.
- ICE King
True Panic , suppose one has to be careful
Bro had the same idling issue(car would switch off when revs got too low, he needed to hold the gas pedal to keep the car idling) on his MP9 Citi , We also replaced MAP sensor with no success , after spraying some carb cleaner down the throttle body's throat and a quick wipe , car started to idle perfectly again.
We couldn't believe it was that simple ,
Well I guess he has nothing to lose seeing it ain't working anyway
