Hi guys,
Just a question, does a mk3 golf GTI take a load reduction starter? The original starter is busted, bought 2nd hand that came off a mk3 golf gts, but either the 2nd one was a dud or the starter is incorrect because it sounds like the battery is dead, its a brand new battery, alternator has been checked, able to push start without any issues. According to the mechanic, I need a load reduction starter? Is this true? if so will GW have one at least?
Sorry if this is noob questions......
starter mk3 golf gti
- Registered for: 9 years 4 months
- Car Model: mk3 jetta cli 2.0
Re: starter mk3 golf gti
gts would have had the same starter. all reduction drive since about the time the time the mk3 came out.
Thank you so much! then the starter i bought was most likely a dud tried jumping it from the battery to the starter and it doesnt take... only a push start works so yeah new starter month end
