1.3 Citi Carb high fuel economy
- Registered for: 7 years
Re: 1.3 Citi Carb high fuel economy
AUG ratios aren't that long and is one of the better ratio gearboxes particularly if you have a 1.6 and anove capacity. The issue here is that, it's a small capacity engine and will always battle up hills with passengers
Consider a simple 1.8 carb engine swop to keep things cheap and simple. A fuel injected motor would be ideal however higher cost factors associated with this conversion
- Car Model: MK1 CITI Shuttle
Thank you yes trying to search 1600 or 1800 carb convertion as FI will cost me to much and i can just sell my car ad the difference and buy a 1.4i or something so comparing costs so far a 1600 carb swop will cost me less than R5000
1800 swop is better.TheBos89 wrote:Thank you yes trying to search 1600 or 1800 carb convertion as FI will cost me to much and i can just sell my car ad the difference and buy a 1.4i or something so comparing costs so far a 1600 carb swop will cost me less than R5000
Not saying 1600 isn't nice, but if you going to do it go big or go home. My one mate had an 1800 sport Citi golf and my other friends had a 1600 Fox back when I was an Appy, the Sport was lighter on fuel every time on the long road. The Fox had a slightly higher top end.
Sent from my SM-J400F using Tapatalk
- Sean Trollope
- Car Make: VW. Hyundai.
- Car Model: Citi golf. Hyundai i10
Its all personal preference. Also the driver makes a difference.
Thankx guys yes for speed i go to the bike much better now a days just looking for light on fuel and reliable
SO decided to use my Diesel ecopsort when traveling the 7 days for lift club so its not to bad and i can spend some time building the golf
- EX-DOHCTOR
- Membership No: 712
As luck would have it, I happen to have a complete 1800 carb motor lying on the floor in my garage. Needs a bit of a clean up and an oil change, new cambelt wouldn't hurt either. As far as I know should start right up.
I'm based in Bryanston too. Let me know if you want to come have a look.
Cool thanx PM sendEX-DOHCTOR wrote: ↑Tue Feb 26, 2019 8:04 pm As luck would have it, I happen to have a complete 1800 carb motor lying on the floor in my garage. Needs a bit of a clean up and an oil change, new cambelt wouldn't hurt either. As far as I know should start right up.
