Hi guys,
a friend has a Citi R-line, which had a missfire, we removed the injectors and found them covered in thick oil, we cleaned them out and tested it. put them back but the car lacks power. Timing is right, the front pulley mark lines up with the arrow on the cover. Map sensor and fuel pressure regulator was replaced. any ideas what could be the issue?
Citi 1.8 R-Line
- chrisg4
- Car Make: Seat
- Car Model: Cupra 1.8T
Citi 1.8 R-Line
Soldier510
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Polo 9n3 1.6i Comfortline
Ex Golf V 2.0 Black Magic
Ex Golf IV 1.6
Ex Jetta II Clx
Ex Toyota Corolla 1.3
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
- Old School Quintin
- Car Model: MK1 16v
Re: Citi 1.8 R-Line
Howsit dude
Did you check the vam shaft and dizzy timing as well all 3 of these has to line up at the same time!
Is the heavy on fuel?
Is the car blowing smoke?
Did you take the injectors in for ultra sonic cleaning?
2008 VW CitiRox
Abf 45mm ITB
Under construction
Seeking ponies
Abf 45mm ITB
Under construction
Seeking ponies
- chrisg4
- Car Make: Seat
Re: Citi 1.8 R-Line
Hi,
cam and crank line up, didn't check the dizzy...
no smoke, he did mention it was heavy on fuel.
we just used some carb cleaner... we ordered new replacement injectors.
will be testing the fuel pressure today.
Soldier510
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
Re: Citi 1.8 R-Line
Please update after the injectors and fuel pressure has been sorted
2008 VW CitiRox
Abf 45mm ITB
Under construction
Seeking ponies
Abf 45mm ITB
Under construction
Seeking ponies
- chrisg4
- Car Make: Seat
Re: Citi 1.8 R-Line
Fuel pressure is around 2.8 bar at idle. When I rev it picks up to about 3.2 bar
Got the injectors. Will fit this weekend.
Soldier510
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
- Colonel
- Membership No: 1041
Re: Citi 1.8 R-Line
timing needs to be advanced to about 6deg, TDC is only your reference point, if car is set on TDC it will explain why the car feels lazy.
you need to plug into Vag diagnostic, put the car into timing mode and advance the timing with the dizzy to about 6deg using a timing light.
