Any one fitted a5 cylinder to citi golf?
- Dub rox
- Car Model: Citi sport 1.4i
Hey guys. Been pondering on this for a while and was wondering if anyone attempted or tried to attempt this sort of mod before. If the space in the bay allows this would be a great performing, sounding citi golf. Any advice and input on this would be of great help.
Sent from my VFD 1100 using Tapatalk
- amstel18
- Car Model: Tiguan Allspace
Re: Any one fitted a5 cylinder to citi golf?
One of the old forum members did, but it didn't work as the driveshaft angles kills the cv's in no time...
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Dub rox
There should be some way? Maybe with the combi box and mounting the engine longitudinally........amstel18 wrote:One of the old forum members did, but it didn't work as the driveshaft angles kills the cv's in no time...
I know back in the day there was a guy with one who used to run at wesbank, no clue what happened to it...
A V5 on the other has been done a lot... and should be done more
- Dub rox
Or maybe the new rs3 motor. Just not shore about the price tag thoughbuffyza wrote:I know back in the day there was a guy with one who used to run at wesbank, no clue what happened to it...
- Dub rox
Or the (i know this is not from the vw family) the subaru ej20 or ej25 with the 4wd setup????Dub rox wrote:Or maybe the new rs3 motor. Just not shore about the price tag thoughbuffyza wrote:I know back in the day there was a guy with one who used to run at wesbank, no clue what happened to it...
Still a great sounding motor and performance wise...........
There's a guy in dbn who has an s3 setup in a golf 1..
The 4wd setup there allows him to run pass rs3's.
Don't know the owner or the specs of this car, just saw it running
5cyl (AAN) style in mk1 using the 020 box makes the left sideshaft very short. It ate cv's at an alarming rate. Turning it longtudinally does not fit unless you are willing to extend the nose somewhow and that was quite beyond anything I wanted to do or ever will want to do.
So for the sound only it simply is not worth the trouble.
Vr5 might be a better solution.
Again the reasoning behind it is a little iffy othr than the uniqueness thing. There are plenty 4cyl engines that will easily match them in HP.
- Neuk
- Treasurer
- Membership No: 806
Didn't BlueBlob do this?panic-mechanic wrote: ↑Tue Oct 16, 2018 8:49 am 5cyl (AAN) style in mk1 using the 020 box makes the left sideshaft very short. It ate cv's at an alarming rate. Turning it longtudinally does not fit unless you are willing to extend the nose somewhow and that was quite beyond anything I wanted to do or ever will want to do.
Bought one with it in. We tried a lot of stuff to make the left inner cv last. just didn't. He eventually sold it because of that.
- Neuk
- Treasurer
Aah, cool, thanks.panic-mechanic wrote: ↑Tue Oct 16, 2018 10:43 am Bought one with it in. We tried a lot of stuff to make the left inner cv last. just didn't. He eventually sold it because of that.
- Dub rox
Was planning on doing a nose job or mid- mount, just not sure wich one yet. Guess it all depends on how much the nose will have to be extended.Neuk wrote:Didn't BlueBlob do this?panic-mechanic wrote: ↑Tue Oct 16, 2018 8:49 am 5cyl (AAN) style in mk1 using the 020 box makes the left sideshaft very short. It ate cv's at an alarming rate. Turning it longtudinally does not fit unless you are willing to extend the nose somewhow and that was quite beyond anything I wanted to do or ever will want to do.
I want something unique and love the sound of the 5 pod. I am also concidering the 2jz and rb26 aswell as the ej25 all for the uniqueness as i want to attempt something new and boldly go were no one has gone before.
The car would not be a dayly drive but will have to be relyable and a strong build.
- Neuk
- Treasurer
You will have to come up with a really unique idea to boldy go where no one has gone before as almost anything and everything has been done to a MkI Golf.Dub rox wrote: ↑Tue Oct 16, 2018 11:35 amWas planning on doing a nose job or mid- mount, just not sure wich one yet. Guess it all depends on how much the nose will have to be extended.Neuk wrote:Didn't BlueBlob do this?panic-mechanic wrote: ↑Tue Oct 16, 2018 8:49 am 5cyl (AAN) style in mk1 using the 020 box makes the left sideshaft very short. It ate cv's at an alarming rate. Turning it longtudinally does not fit unless you are willing to extend the nose somewhow and that was quite beyond anything I wanted to do or ever will want to do.
- Dub rox
Should have said " and done it succesfully"Neuk wrote:You will have to come up with a really unique idea to boldy go where no one has gone before as almost anything and everything has been done to a MkI Golf.Dub rox wrote: ↑Tue Oct 16, 2018 11:35 amWas planning on doing a nose job or mid- mount, just not sure wich one yet. Guess it all depends on how much the nose will have to be extended.Neuk wrote:Didn't BlueBlob do this?panic-mechanic wrote: ↑Tue Oct 16, 2018 8:49 am 5cyl (AAN) style in mk1 using the 020 box makes the left sideshaft very short. It ate cv's at an alarming rate. Turning it longtudinally does not fit unless you are willing to extend the nose somewhow and that was quite beyond anything I wanted to do or ever will want to do.
I also did some resurch on electric conversions and decided to abandon the idea for the insane price tag that would acompany this.
- Neuk
- Treasurer
Lots has been done successfully.Dub rox wrote: ↑Tue Oct 16, 2018 11:48 amShould have said " and done it succesfully"Neuk wrote:You will have to come up with a really unique idea to boldy go where no one has gone before as almost anything and everything has been done to a MkI Golf.Dub rox wrote: ↑Tue Oct 16, 2018 11:35 amWas planning on doing a nose job or mid- mount, just not sure wich one yet. Guess it all depends on how much the nose will have to be extended.Neuk wrote:
- PoloB
- Car Model: POLO 6S
"I also did some resurch on electric conversions and decided to abandon the idea for the insane price tag that would acompany this."
If you did this for the sound aspect of it do you like the sound of vacuum cleaners or hair dryers then?
Vw Polo 6 Sedan
Quantum Tunning Software
Eibach Springs
Smoked Tail lights
17 Inch A-Line Spree wheels
Eibach Springs
Smoked Tail lights
- Dub rox
Will still do it non the lessNeuk wrote:Lots has been done successfully.Dub rox wrote: ↑Tue Oct 16, 2018 11:48 amShould have said " and done it succesfully"Neuk wrote:You will have to come up with a really unique idea to boldy go where no one has gone before as almost anything and everything has been done to a MkI Golf.Dub rox wrote: ↑Tue Oct 16, 2018 11:35 am Was planning on doing a nose job or mid- mount, just not sure wich one yet. Guess it all depends on how much the nose will have to be extended.
- PoLonY
- Car Model: A8
- Membership No: 1997
If insane price tags scare you then I can’t see how you’d want to do a 2JZ or RB26 setup properly on a Mk1
- Dub rox
Lmfao The electic part of this conversation was actually concidered for the power delivery they give, not to speak about the independance aspect of it as i also concidered a solar charging station to accompany the build.PoloB wrote:"I also did some resurch on electric conversions and decided to abandon the idea for the insane price tag that would acompany this."
- Donavan
Back wheel drive conversions will suit the above motors way better, sometime ago there was a red Caddy with a 7m turbo real wheel setup running at ODI.I want something unique and love the sound of the 5 pod. I am also considering the 2jz and rb26 aswell as the ej25 all for the uniqueness as i want to attempt something new and boldly go were no one has gone before.
Principal might be the same when doing a real wheel drive setup on a MK1, it will have to a be complete relocation of the firewall and floor pan to accommodate everything.
Audi A4 B8 2.0T - Daily
- Dub rox
Motor about R30k. GearboxR10k. Management R10k. Sodimication, mounts, sutpension, brakes, wireing etc R50-60k. All and all around R100k.PoLonY wrote:If insane price tags scare you then I can’t see how you’d want to do a 2JZ or RB26 setup properly on a Mk1
Electric wise the motor alone is about R100k not to speak of controllers and correct batteries and inport costs as our lovely country is not so advanced so we can source all the propper parts and accesories locally.
- Dub rox
The mid-mount was also my first choice for the weight distribution and space for the motor and gearbox part but there is also a space concideration to in mind as the front seats might be to far forward.Donavan wrote:Back wheel drive conversions will suit the above motors way better, sometime ago there was a red Caddy with a 7m turbo real wheel setup running at ODI.I want something unique and love the sound of the 5 pod. I am also considering the 2jz and rb26 aswell as the ej25 all for the uniqueness as i want to attempt something new and boldly go were no one has gone before.
- Dub rox
"Tipo" keep in mindDub rox wrote:The mid-mount was also my first choice for the weight distribution and space for the motor and gearbox part but there is also a space concideration to in mind as the front seats might be to far forward.Donavan wrote:Back wheel drive conversions will suit the above motors way better, sometime ago there was a red Caddy with a 7m turbo real wheel setup running at ODI.I want something unique and love the sound of the 5 pod. I am also considering the 2jz and rb26 aswell as the ej25 all for the uniqueness as i want to attempt something new and boldly go were no one has gone before.
- Neuk
- Treasurer
Well, there goes the uniqueness, copy cat
- PoLonY
- Car Model: A8
I said properlyDub rox wrote:Motor about R30k. GearboxR10k. Management R10k. Sodimication, mounts, sutpension, brakes, wireing etc R50-60k. All and all around R100k.PoLonY wrote:If insane price tags scare you then I can’t see how you’d want to do a 2JZ or RB26 setup properly on a Mk1
Not thumbsucked Numbers lol
