Removing catalytic converter
- PoloB
- Car Model: POLO 6S
Hi,
Has anyone removed the cat on their vehicles any advice if I want to remove mine what needs to stay and what can go?
What is the implication of removing the cat, any warning lights etc. that would need to be cancelled?
Reason for asking is my exhaust silencer box first one after engine has cracked open at the seam (apparently a common polo problem) vehicle just done 36756km still under warranty but don't really care as I would rather want to go with performance setup as the OEM sounds terribly kak!!!(Only 2 months left of warranty anyway)
So I was thinking of removing the whole OEM system and doing a 4-1 Branch setup from Autowerkz in Durban and going with a stainless freeflow.
Any advice will be greatly appreciated.
Vw Polo 6 Sedan
Quantum Tunning Software
Eibach Springs
Smoked Tail lights
17 Inch A-Line Spree wheels
Eibach Springs
Smoked Tail lights
- ICE King
Re: Removing catalytic converter
Your options are as follows:
1. Remove Cat and re weld on flange onto new exhaust for Cat Sensor- Probably the easiest
2. Remove Cat and sensor, install resistor for sensor circuit to close
3. Remove Cat and delete Cat sensor from ECU map - Needs Mapping
In short you cannot just remove the sensor without closing the circuit - then you'll have a dash light on.
- PoloB
Can a tech at VW do option 3 on their clever pc's or it this something they won't do?ICE King wrote: ↑Tue Sep 18, 2018 1:30 pm Your options are as follows:
Vw Polo 6 Sedan
Eibach Springs
Smoked Tail lights
Eibach Springs
Smoked Tail lights
- ICE King
VW wouldn't dare despite having the tools to do so , Will need to locate a " aftermarket" tuner - best closet to your area.
I see your car has software already?
also since you mentioning branch and not down pipe, do you have a non-turbo polo 6?
- PoloB
Yes already did software a month ago.
Yes non turbo 1.6 polo
Vw Polo 6 Sedan
Eibach Springs
Smoked Tail lights
Eibach Springs
Smoked Tail lights
- PoloB
Cant remember if the guy said the Cat delete was included in the software tune or not. Will have to make sure
Vw Polo 6 Sedan
Eibach Springs
Smoked Tail lights
Eibach Springs
Smoked Tail lights
- ICE King
Usually is but will have to make sure, If it is then you good to go for a exhaust system
Will wake the car up nicely at the top of the rev range
- PoloB
ICE King wrote: ↑Tue Sep 18, 2018 3:05 pmUsually is but will have to make sure, If it is then you good to go for a exhaust system
Any suggestions on what size free flow would work best? Don't want a loud blaring sound either just a nice deep growl
Vw Polo 6 Sedan
Eibach Springs
Smoked Tail lights
Eibach Springs
Smoked Tail lights
- Car Model: Mk4 Jetta V5 AGZ
This is exactly what i wanted to know. Thanx for posting and the replies.
- ICE King
50mm mild steel piping , a free flow resonator up front and free flow silencer box at the back ,Gives a nice clean sound , Quiet when idling and loud enough on top , also no drone when cruising high speeds.PoloB wrote: ↑Wed Sep 19, 2018 7:20 amICE King wrote: ↑Tue Sep 18, 2018 3:05 pmUsually is but will have to make sure, If it is then you good to go for a exhaust system
Note: Peoples opinions differ , I've always prefer mild steel over stainless - It has a deeper complete tone and absorbs the resonating sound.
- PoloB
Thanx for the info,
I would prefer stainless due to the lasting quality as mild steel tends to rust to soon. But yes I also like the deeper exhaust note and not that Mazda Rx7 sound you hear for 1km away.
Might also go with mild steel then and I don't want my car sounding to loud as it a daily drive and use it for long holiday trips, will go mad with a blaring exhaust for 700km
Vw Polo 6 Sedan
Eibach Springs
Smoked Tail lights
Eibach Springs
Smoked Tail lights
- Dub rox
- Car Model: Citi sport 1.4i
You could also keep your standard zorst as they are normally stainless. Just do a decat and your ears won't bleed on long trips. Your power and fuel consumption should better provided your not to trigger happy with the results. Just my two cents
"Remove Cat and sensor, install resistor for sensor circuit to close"
Would the resistor value be the same for all cars? I have a 2000 model v5 agz engine
- Dub rox
Or you could fit a mini cat. They are about R600. I speak under correction but if your sensor is before the cat not neccesary but if it is positioned behind the cat it is. Any one have an opinion on this?Gummi wrote:"Remove Cat and sensor, install resistor for sensor circuit to close"
Sent from my VFD 1100 using Tapatalk
If the car has an upstream sensor only (only 1 sensor) it doesnt need a minicat.
If has 2 sensors, upstream and downstream then u will need a minicat as the downstream o2 is a cat efficiency sensor..
Well im popping around by Powerflow in next week. Will check then how many sensors and also what they say. As far as i know, 2 sensors take into account what the difference between them are. Not sure what it does with that info though. Will keep you guys posted.
- PoloB
Unfortunately mine has 2 sensors one before and one after
Vw Polo 6 Sedan
Eibach Springs
Smoked Tail lights
Eibach Springs
Smoked Tail lights
- Dub rox
The sensor "down stream" lets you know when the cat is fubar and need replacing. The other measures your co for correct fueling.PoloB wrote:Unfortunately mine has 2 sensors one before and one after
