Need to have the clutch done on my 2006 1.4 Citi/Chico with carb motor.
Which flywheel/clutch does the carb motor have? Double or single dowel, 6 or 9 bolt?
I think these late-spec Golfs were built with whatever was left on the factory floor, but would be nice to find out if there's some indication on which motors have which setup (something along the lines of ETKA part continuation, etc). I have search, but I feel like the "life is like a box of chocolates..." thing is happening.
Would like to order the clutch before taking to mechanic (got to put it on credit unfortunately until month end ).
Citi 1.4 carb clutch/flywheel... which one?
- Registered for: 21 years 2 months
- Car Model: 2017 Cross Polo 1.2 TSI
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
1989 Audi 500 turbo (the end. finally.)
Re: Citi 1.4 carb clutch/flywheel... which one?
Managed to find info.
BSC motor (1.4 carb, 54KW) is listed as having the 200mm flywheel/clutch, 6 bolt centre. Will just order that and then confirm on disassembly.
always the best to have the sample in hand first but most likely single dowel 6 bolt.
200mm?
Seeing 190mm for GY, 200 for everything else 1.4.
think it's 200 mm. But a Goldwagen will most likely be able to tell you what the right one is.
Thank you
- Tankane
- Car Make: VW Citi Golf
- Car Model: 1.4 Carb 2007
It's 200mm, I was at spares yesterday and they confirmed that.
