Citi Golf Mk 1 Electrical or computer box problem
Charldon
Registered for: 6 years 8 months
Car Model: Mk1 citi 1.4i
Post by Charldon »
What’s up guys I’m wondering if someone could help me
I drive a 2008 Citi golf mk1 1.4i
I think I’m having problems with the electrical or the cars computer box so what happens is The car starts and drives fine and all the electricals are working But as soon As i turn the car off The car it loses power and is completely dead for maybe 10 seconds While the car is restoring its power the cluster gauges and trip meter has lines through it and it makes a weird glitch then when all electrical power eventually comes back Everything has resetted it self.
Sometimes if I listen to music When the car is off it will also lose Power and everything resets again for no reason I have checked all the fuses and the battery is new the terminals are clean and I figure it can’t be a ignition switch and everything is grounded perfectly.
PoloMike
Car Model: 1998 Polo Classic 1.8
Re: Citi Golf Mk 1 Electrical or computer box problem
Post by PoloMike »
HI
Sounds like you might have a short somewhere.
1998 Polo Classic 1.8 with added "benefits" :violin:
Fidgeter
Post by Fidgeter »
Sounds like a faulty battery. What size battery are you using and which brand? New batteries can also give problems
2005 Citi Golf
Current mods: 2lt 8v Single throttle
Estas cam
Branch with 57mm exhaust
Charldon
Post by Charldon »
Hi thanks for the reply We figured out that it was a faulty ground cable we just cleaned the ground Cable which is attached to the body
Charldon
Post by Charldon »
