2l 8v engine problem
speedfreex
Car Model: G1 2l 8v
Post by speedfreex »
Have a 2l 8v mp9 system on my golf 1 2000model...car use to run perfectly after being parked off for a while now but started now and again just to keep it running and turning the motor over.
last start was 5 weeks ago before planning to rebuild car in terms of body work n cosmetics...car started perfectly n I filed for 10mins no problems
Plan was to rebuild car and run daily...car is completely built up again but now have a problem with engine.
The car starts on the turn every time but only revs or idles for 10seconds every single time then switches off
I have installed a new fuel pump new coilpack new leads plus service done but still it starts the same only idles for 10 seconds then switches off
How would I go about finding out what's the problem.
Thank you for the replies in advance🙋
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
JETTA 2 1.6 (STRIPPING FOR SPARES)
Call for what u want
JETTA 2 1.8 (customer repairs)
Front smash
OPEL CORSA 1.4 LITE ( customer repairs )
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
speedfreex
Car Model: G1 2l 8v
Re: 2l 8v engine problem
I suspect it to be an electrical fault
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
Fidgeter
Post by Fidgeter »
Did you check out your dizzy? it could possibly be a faulty hall sender
2005 Citi Golf
Current mods: 2lt 8v Single throttle
Estas cam
Branch with 57mm exhaust
Sounds like a fuel pressure problem.
speedfreex
Car Model: G1 2l 8v
Ok but I fitted a new fuel pump same as to the old one when the car use to run.
How would I go about checking the fuel pressure?
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
speedfreex
Car Model: G1 2l 8v
Fidgeter wrote: Thu Aug 02, 2018 8:22 pm Did you check out your dizzy? it could possibly be a faulty hall sender
Not really once I had spark and car turns over I ruled out the distributor
A friend suggested I connect a test light to the 3 wires lead in to distributor to see if continuous power was supplied...light came on turn of ignition and stayed on while running and after car switched off the light still remained on.
That's why I ruled out the distributor
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
speedfreex
Car Model: G1 2l 8v
So what do I need to do to check out the dizzy n hall sender to rule this issue out
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
Fidgeter
Post by Fidgeter »
Maybe try another distributor. We had the issue very similar issue you are having on my brother's 2lt 8v. Changed leads,plugs,coil same problem when we put the new distributor the car ran 100% and still is.
2005 Citi Golf
Estas cam
speedfreex
Car Model: G1 2l 8v
Ok thanks will try this
Are all the distributors the same?
I have a 1.6 jetta 2 1989 distributor ( carb model ) will this work?
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
no not all distributors are the same. That carb dissy most likely have a vacuum advance unit.
PapaJo
Registered for: 14 years
Car Make: VW's
Post by PapaJo »
The hole size in the block where dizzy fit in block differ too.
speedfreex
Car Model: G1 2l 8v
Ok I fitted the the distributor from the jetta
At first I was not getting any spark
Then I think the starter gave up cos its just making a clicking noise and is barely turning the motor. Its like the teeth on the starter are worn out and cannot turn the flywheel
Have a starter from the jetta will it fit n work?
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
Naku786
Cake Laaitie Killer
Registered for: 13 years 4 months
Car Model: Citi 1.9i 8v
Post by Naku786 »
Brushes on starter most likely gone, you can get it repaired... If it's clicking then bendix not engaging to turn the flywheel.
To answer you question a "jetta" starter will work if from a mk2/3
Sent from a phonebooth in Hillbrow
speedfreex
Car Model: G1 2l 8v
Naku786 wrote: Mon Aug 13, 2018 3:19 pm Brushes on starter most likely gone, you can get it repaired... If it's clicking then bendix not engaging to turn the flywheel.
Have a jetta 2 1.6 1989 carb model which I'm stripping for spares for sale...so have the starter from there to fit on my golf 1 2l 8v
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
Fidgeter
Post by Fidgeter »
It should fit
2005 Citi Golf
Estas cam
speedfreex
Car Model: G1 2l 8v
Ok will try it out
Then back to my other issues
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
mike65
Registered for: 8 years 10 months
Car Model: mk1
Post by mike65 »
the starter will fit but most probly wont turn the engine as its to weak i had this starting issue with my 2lt and replaced it with the golf 4 sr starter and all went well after that
Watch this space
