Hi guys can I swap the 1.3 4 speed gearbox with a 5 speed gearbox from a 1989 jetta 2 1.6 5 speed gearbox? If so would it be a straight swop out or would I have to change some parts from 1 gearbox to fit the other?
Would appreciate the replies
golf 1 1993 4 speed gearbox
- Car Model: G1 2l 8v
GOLF 1 2l 8V
CHEV SPARK 1.2 16V
JETTA 2 1.6 (STRIPPING FOR SPARES)
Call for what u want
JETTA 2 1.8 (customer repairs)
Front smash
OPEL CORSA 1.4 LITE ( customer repairs )
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
CHEV SPARK 1.2 16V
Front smash
Clutch replacement
Chrissautoworks
Dbn repairs
0791037438
Re: golf 1 1993 4 speed gearbox
Yes, you can. You will also need the rear 5 speed gearbox mounting at the battery side, gear links, the arm that fit on the shaft from underneath the car, possibly inner CV’s as the diameter is 100mm and currently 90mm on 4 speed, plastic gear that fit in the gearbox on gearbox cable. Clutch and pressure plate and flywheel upgrade to 210mm from 190mm.
- Car Make: ShitiGolf + CRX
Find the code of the gearbox from the jetta first.
Also 1989 would be an old gearbox
As for the shift linkages they can be modified rather than replaced so long as you can measure cut and weld XD
