MK3 GS '95 DOESNT START ON COLD MORNINGS
SDAYA
Registered for: 9 years 9 months
Post by SDAYA »
Hi Guys
I've never had issues with my car starting at any time but lately with this cold weather it doesn't start in the morning.
The engine swings but doesn't ignite?
When I get home in the afternoon and the weather is a bit warmer then the car starts with no issue.
It's like two different cars.
Any help please? Image
Pynoxim
Re: MK3 GS '95 DOESNT START ON COLD MORNINGS
Post by Pynoxim »
'95 is Carburettor?
Thursday Milkshake Crew
'00 GS2 Lexus GS300
SDAYA
Post by SDAYA »
Yes
Sorry I didn't mention that
VAG Fan
Post by VAG Fan »
I'm not familiar with the carburetor in the Mk3. Does it have a manual or automatic choke?
SDAYA
Post by SDAYA »
Manual choke
I have to pull it out and push it back
So take the aircleaner off and see if it actually closes the flap in the carb when you pull it.
Oh and get some quick start from a spares shop. Spray it into the air intake one morning. If it fires it is fuel related. If not then spark related.
SDAYA
Post by SDAYA »
Thank you
Will try
☆KalaMK3
Registered for: 8 years 8 months
Car Model: MK3
Post by ☆KalaMK3 »
panic-mechanic wrote:So take the aircleaner off and see if it actually closes the flap in the carb when you pull it.
I pressume its the "perculator" (device mounted infront of the head/tappet cover that feeds from the fuel to itself, has a return, and then feeds the carb).
I had a similar issue prior to the swap when I was still running carb
SDAYA
Post by SDAYA »
So yesterday in the afternoon I tried straying the car
It swinged and ran for like 2 sec each time and died out until it just swang
Not sure what the issue was
Cause each time it started I tried either accelerating or pulling the choke out but it still died
Will attempt today cause weather is better
Car never gives me trouble in the heat ..
Only when it's cold
Supervan II
Registered for: 18 years 8 months
Car Make: SEAT
Post by Supervan II »
Battery on its way out?
SDAYA
Post by SDAYA »
Does a battery make nonsense during cold?
Rascal69
Registered for: 16 years
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
SDAYA wrote: Sun May 20, 2018 12:00 am Does a battery make nonsense during cold?
Yes... Get it checked or tested..
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
PapaJo
Registered for: 14 years
Car Make: VW's
Post by PapaJo »
Rascal69 wrote: Sun May 20, 2018 11:00 am
But then motor will not swing over.
Did you follow panic’s advise as mentioned earlier i a post?
Also check for vacuum leaks on intake and carb base plate rubber and your fuel supply to carb.
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
PapaJo wrote: Sun May 20, 2018 2:28 pm
i'm just saying its easy to check the battery... I've had many batteries fail during winter thats why i invested in a battery charger.
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
VAG Fan
Post by VAG Fan »
Of course, batteries fail more often in winter, but one of the first symptoms of battery failure is that the engine swings too slowly, or not at all. If the engine swings normally but doesn't ignite, like the OP wrote, then there is no need to check the battery. But suit yourself...
