Dissapointed in power
- ☆KalaMK3
- Car Model: MK3
Hi all. I am a tad dissapointed w.r.t power on my APK import. Motor was rebuilt and running a 276 cam + 4-2-1 branch + stock 1.6 mk3 zorst, rest is stock. 60-2 dictator tuned at 2 tuners with the max output of 72wkw.
Any reasoning or info as to why she pulls so swak would be appreciated.
Pic of dyno sheet attached.
Re: Dissapointed in power
The stock 1.6 mk3 exhaust is robbing you of more power.
- ☆KalaMK3
- Car Model: MK3
30kw of power?PapaJo wrote:The stock 1.6 mk3 exhaust is robbing you of more power.
- ☆KalaMK3
- Car Model: MK3
20kw*
APK motor is rated by VW to have 85kW and 170nM at the flywheel, at the coast.
Drivetrain losses, altitude, warra warra, and the 72kW ATW is not a bad figure, actually.
- RedBeard
- Car Model: Mk1 2-door Golf
Could be stuck with 50 odd kw like i am
Daily : 2011 Toyota Aygo 1.0 (Tiny)
Soon-To-Be-Project : 1981 VW Golf 2-door (Unikorn)
Link for slow build - viewtopic.php?f=11&t=208217
Ex : 2005 Hayundai Getz 1.3(Chuckie)
- ☆KalaMK3
- Car Model: MK3
Yet stock 2e's etc pull more?Jetta2 wrote:APK motor is rated by VW to have 85kW and 170nM at the flywheel, at the coast.
2E motor is also rated at 85kW at the flywheel at the coast.
And remember this: no two dyno readings or dyno operators are the same, so comparing your cars output to someone elses that was was done on a different dyno on a different day under different conditions in a different city at different altitude is 100% pointless.
And like Papajo said, the stock 1.6 exhaust is holding back some power. Definately not 20kW worth, but some.
72wkw not taking account losses due to drive train would be around 92-94kw on flywheel.
Dependes on the flow chararistics and brand of a free flow system, you could on average expect an increase of maybe up to 3kw if you are lucky.
51mm to 57mm progressive exhaust system is a good size for a 2L motor wirh cam.
- ☆KalaMK3
- Car Model: MK3
I'll pass, will do compression test, check fuel pressure and then slap on a turbo kit.
- ☆KalaMK3
- Car Model: MK3
Yo bud. I see that you have done an 8vT on stock bottom end. Anymore info on this? I would obviously do as stated above firstly, and would want it te be reliable.Jetta2 wrote:2E motor is also rated at 85kW at the flywheel at the coast.
It was built over lots of years and lots of trial and error. I will not even go into the cost aspect. It was an expensive learning curve.
In the end, a stock ADY motor was used, spacer plate to drop the compression ratio, ARP studs in the stock conrods, stock pistons, X-flow head, custom designed inlet manifold, custom exhaust manifold, Perfect Power XMS5 tuned by Panic, tons of custom one-off bits, and did 195kmh on the 1km at ODI, and did a reliable 240.5Hp (179kW) and 301Nm ATW on 0.9Bar boost with a Garrett GT2871R ball bearing turbo on Panic's dyno.
That power is about spot on for the reef and as mentioned restricted by the exhaust system. I'm unsure what kind of power numbers you were expecting.
Remember up here you have 17% less than the advertised numbers from any factory as that is rated to sea level flywheel KW.
- ☆KalaMK3
- Car Model: MK3
Where did you obtain the spacer?Jetta2 wrote:It was built over lots of years and lots of trial and error. I will not even go into the cost aspect. It was an expensive learning curve.
- ☆KalaMK3
- Car Model: MK3
Several tuners and others running 8v setups expected atleast 90wkw so was obviously a tad dissapointed. I did pm you though regarding some tech questions should you not mind answering. I will obviously go the route as jetta 2 stated and will obviously be saving plenty as my dad is a specialised welder and the plumbing and custom bits wont touch my pocket that much. Motor was rebuild with new hardware all round so just planning on doing ARP rod bolts and copper gasket maybe?panic-mechanic wrote:That power is about spot on for the reef and as mentioned restricted by the exhaust system. I'm unsure what kind of power numbers you were expecting.
I also saw on your panic's place post there is a number we can message. Would you mind me contacting you there
Unless there is a LOT of work going into an apk in N/a form ther is no way that thing is making 90 wheel kw at the reef.
That is the stuff pipe dreams are made of.
- Car Make: Merc
- Car Model: C63 Edition 507
not bad about 8wkw off what a stock fiesta st150 make on reef
Polo 20VBigT - The Redhead
C63 507 Edition - The Dragon
Isuzu 4x4 - Little Joe
- ☆KalaMK3
- Car Model: MK3
They 1.6T right?Stu wrote:not bad about 8wkw off what a stock fiesta st150 make on reef
2.0 naturally aspirated.
- Car Make: Merc
yip Jetta2 is right they 2L NA motors - new fezz st180 is 1.6L T
