9a and pl mk1 conversion possible
- 162life-WP
- Car Model: Mk1 Life
Re: 9a and pl mk1 conversion possible
Awesome just thought I could add some ideas that helped me.more posts in future tho man, we r all patiently waiting the start up
Sent from my FIG-LX1 using Tapatalk
If motor is hanging too much to the rear, your mounting below gearbox might be sagging out. Getting a new rubber mount or spacer in there will tilt motor more forward and could give you more clearance on brake pipes.
That whole problem is easily avoided by running wasted spark
- 162life-WP
Lol So True. wish someone convinced me more before I went std lol. is what it is thopanic-mechanic wrote:That whole problem is easily avoided by running wasted spark
Make it work with what you have. We want to see a video on the dyno.
- 162life-WP
+1 x100PapaJo wrote:Make it work with what you have. We want to see a video on the dyno.
- blou_poot
- Registered for: 10 years
Thanks everyone... Will do once i get thing done...
Already had the Dicktator STD for a few years now. Just lying around... So was cost saving...
Did not do enough research beforehand regarding the dizzy...
But anyway going to be selling my brake booster and the new master cylinder to make money available for the big brake upgrade...
And will be doing a booster delete keeping my oem master cylinder. Just a question... Do i need a bias in order for it to work or would the bias be unnecessary?
Would look a lot cleaner.
Then thoughts and budgets need to be gathered regarding next mods...
Sent from my RNE-L21 using Tapatalk
96' Chico 2.0 Carb
Bias valve sits under the car at the rear axle. Not sure how not having it will make things neater? Do you regularly have people looking under your car?
- blou_poot
This is what I mean...
Thought this is what it was called...
96' Chico 2.0 Carb
- blou_poot
Car also gets worked on so much so yes... Lots of people looking under it... Lol
96' Chico 2.0 Carb
You have to decide if you need it. Those are normally found on racing cars to turn DOWN the rear braking and the normal factory fitted to the axle bias valve is removed.
- blou_poot
Thanks Panic,
So will just get me the bigger brakes and the brake m/c delete flange.
96' Chico 2.0 Carb
- blou_poot
Struggling to get a clutch... Second time having issues with a sachs thats brand new... Waiting on luk stock...
Car was broken into week or two ago.
Brakes are in just need to get the brake lines fitted exhaust fitted and dyno... Rest is basically done... Start up and most of the stuff is sorted.
96' Chico 2.0 Carb
Hope you get everthing sorted soon and drive the car. Been a while since you started the engine swap.
- blou_poot
Yip couple if months now... Motivation a lil lacking... Due to obstacles... Also been busy with work and having a baby on the way...
96' Chico 2.0 Carb
- blou_poot
Hi guys so with a little more time available i have done a couple of things.
Replaced clutch again removed the sachs and replaced with the luk (was a struggle finding one) all good now on the gears side.
Added the new bigger brake system and did a booster delete fitted new brake lines as well (sjoe what a pain... Had to display measures of patience tgat i never had)
Now question since the fluid is out do i need to bleed the brakes or can i just fill and test( in the yard of course)
96' Chico 2.0 Carb
Do a proper bleed through on the brake system don’t risk testing it in the yard to be fine and no brakes on the roads when you need it.
- blou_poot
Will do, then kt would have to wait till the weekend... Need to get exhaust still sorted and then dyno...
96' Chico 2.0 Carb
- blou_poot
Will do.
Anybody visiting nam soon? Want another fuel rail.
96' Chico 2.0 Carb
- blou_poot
The one similar to this...
96' Chico 2.0 Carb
That looks similar to the mrturbo one they had a while back.
- blou_poot
Yes exactly... I need to get one or alternatively make time to make clips/brackets to mount them as the guy who sold me mine didnt include any
96' Chico 2.0 Carb
