Hi there, please help a lost soul, my velocity all of a sudden decided that the brake lights are not working, including the eyeline brake light in the rear window, indicators, lights and reverse lights all working thought, just the 3 brake lights thats giving me a headache
Velocity brake lights
Re: Velocity brake lights
Check the brake light switch on your brake pedal, it might be faulty and needs to be replaced or just came loos.
Thanx, will check it out, thought it might be a fuse, but cant see anything wrong there, but when it comes to electrical issues, I'm basically just a clown at a graduation sermonTDIFlava wrote:Check the brake light switch on your brake pedal, it might be faulty and needs to be replaced or just came loos.
- Hazaree7
- Car Model: Velociti 1.6i & Polo 1.9TDI
Hi
Did you manage to sort this out ?
Was it the brake light switch?
I'm currently experiencing the same issue
Just for information:
Brake switch
Located behind the brake pedal, it is spring loaded, when you press the pedal it goes into on position and switches on your brake lights.
When you release the pedal it goes into off position and switches off your brake lights.
You take it out by twisting it and pulling.
Brake switch
175SBU wrote: ↑Sun Dec 03, 2017 8:45 pm Just for information:
Brake switch
These visuals help a lot brother.
Ta.
Glad i was able to help.
