Polo 6r 1.4 Oil Light flashing after oil change
- Registered for: 8 years
- Car Model: Polo 6r 1.4 Comfortline
Serviced my car yesterday. after leaving the house back to work after lunch today, I noticed the oil light came on with beeps and flashed red. Pulled over and checked the oil level. Oil level is correct just under the max. When I filled it yesterday with 3.2litres it read just a bit over max, thought it would be a little over as I put in the new oil filter.
I am really worried. What could be the issue.
- Unobeat
- Car Model: Uno, Auris, CX-5
Re: Polo 6r 1.4 Oil Light flashing after oil change
Recheck the oil level again once the motor is slightly less hot and on a level surface.
After a service, i usually start the car up and let it run for a few minute and recheck the oil to make sure that it is on the correct level.
not sure if this would cause it, but did you fill some oil in the filter before installing it.
[Audi A3 2.0T http://vwclub.co.za/forum/viewtopic.php?f=11&t=177350]
Polo Playa 1.6 Oo oO
Ex: Polo Playa 1.8 - Sold
I checked the oil level last night and it was fine. I used magnatec 5w40 full syntheticUnobeat wrote:Recheck the oil level again once the motor is slightly less hot and on a level surface.
It is not the yellow warning light. It is the red warning light. I'm dreading the drive home.
- Unobeat
If its the RED sign with STOP engine then sounds like it is pressure related being low, methinks.luqies wrote:I checked the oil level last night and it was fine. I used magnatec 5w40 full syntheticUnobeat wrote:Recheck the oil level again once the motor is slightly less hot and on a level surface.
Does the oil pressure warning light keeps flashing red with three long beeps while driving when the temperature near or at operating temperature and it disappears for a while and then comes again?
How many kilos on the clock?
Does the motor sound rough and loud?
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
3.2 litres sounds low especially with a change of filter. Have you serviced the car before in the exact same manner with the same volume of oil? The dipstick may be reading incorrectly if it has been replaced in the past with an incorrect unit.Engine oil
Caution
The oil capacity has been revised for engines manufactured from June 2011
The engine oil level must always be checked with the dipstick and adjusted as necessary → Fig.
Oil capacities
Engines to May 2011: with oil filter 3.6 l
Engines from June 2011: with oil filter 3.9 l
- Unobeat
THANAS wrote:3.2 litres sounds low especially with a change of filter. Have you serviced the car before in the exact same manner with the same volume of oil? The dipstick may be reading incorrectly if it has been replaced in the past with an incorrect unit.Engine oil
Caution
Oil capacities
Now you onto something here, good points.
I was about to check the manuals for info on oil capacity.
Yes 3 beeps then it flashes and then goes away and comes back again with that scary 3 beeps. The beeps only came on when the car was at operating temp. Engine sounds normal and definitely drives well if not better then before the service.Unobeat wrote:If its the RED sign with STOP engine then sounds like it is pressure related being low, methinks.luqies wrote:I checked the oil level last night and it was fine. I used magnatec 5w40 full syntheticUnobeat wrote:Recheck the oil level again once the motor is slightly less hot and on a level surface.
Caution
Oil capacities
First time i'm servicing the Polo. I have my oil in the boot. I am going to top up to 3.5 and monitor
The car is on 54000kmUnobeat wrote:THANAS wrote:3.2 litres sounds low especially with a change of filter. Have you serviced the car before in the exact same manner with the same volume of oil? The dipstick may be reading incorrectly if it has been replaced in the past with an incorrect unit.Engine oil
Caution
Oil capacities
I used the shell website to work out how much oil to putTHANAS wrote:3.2 litres sounds low especially with a change of filter. Have you serviced the car before in the exact same manner with the same volume of oil? The dipstick may be reading incorrectly if it has been replaced in the past with an incorrect unit.Engine oil
Caution
Oil capacities
CLPA
CGGB
I used the CGGB to be on the safe side. I then checked dipstick and it was fine. I want to know if my car is safe to drive like this
- Unobeat
I wont not risk driving it in that state as you don't what other damage is caused while driving it in that state.
now I'm really puzzled. It seems like the oil is over the max level.
Could this cause the problem?
- vee4410
Possible, try draining some oil and see if the problem persists.luqies wrote:now I'm really puzzled. It seems like the oil is over the max level.
2007 Polo 9n3 1.9 TDI
2004 Polo 9n 1.6
2015 MB w205 C180
2004 Polo 9n 1.6
2015 MB w205 C180
- THANAS
- Forum Advertiser
It could also be:
1. Incorrect oil spec
2. Incorrect oil filter
3. Incorrectly installed oil filter
4. Defective oil filter
I put the old filter back. No more warning light. I can't believe they gave me the wrong filter. I should have checked before fitment. I thought the GUD maybe just looks different . What must I do with the part? Will Midas take it back?
Sent from my GT-N7100 using Tapatalk
- amstel18
- Car Model: Tiguan Allspace
Buy the filter from VW.
As far as I know those filter have some type of non return valve in it, and some of the aftermarket filters don't have this.
Filters from VW aren't that much more expensive that the aftermarket stuff
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Unobeat
amstel18 wrote:Buy the filter from VW.
Correct bro.
HEre is a pic of the 2 filters.amstel18 wrote:Buy the filter from VW.
It's obvious now that I used the wrong part. I assumed it was just an aftermarket that's why it looked different.
Will a shop take back a part that was put in a car already?
- vee4410
Used oil filter will not be taken back. Just make sure you have the part numbers/ engine info whenever you purchase parts and always compare before installing as you can return unused parts.
2004 Polo 9n 1.6
2015 MB w205 C180
2004 Polo 9n 1.6
2015 MB w205 C180
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
when I get to work I will get you the GUD part number-correct one....the guys at spare shops are sometimes a bit idiotic with their referencing
You know when I was there they even asked each other what part number and made sure it was not the VIVO filter. I thought they really knew what they doing that's why I didn't think it was odd that the filter looked a bit different. The fact that it screwed on properly I thought it should have been correct. Anyway I facebooked them and they want me to come in and see why this happened. Hopefully I get the refund. I just hope there was no damage don to my engine8VALVE-zn wrote:when I get to work I will get you the GUD part number-correct one....the guys at spare shops are sometimes a bit idiotic with their referencing
OK so after tackling a very slow system this morning I have the most accurate data for your purchase on the new Filter.
Z404 (GUD) if your OE number is 030-115-561T
Z567 (GUD) if your OE number is 03C-115-561D
Hope this serves you well, oil issues are the worst and should be sorted out right away.
Thanks. I got the Z567.8VALVE-zn wrote:OK so after tackling a very slow system this morning I have the most accurate data for your purchase on the new Filter.
Just by the way the GTi uses the same oil filter.
I know this is an old post but im having the same issue and I bought an after market oil filter on my 2017 polo vivo 1.4 clp engine im going to buy an original from VW and will see how it goes
