does a std abf piston protrude the bore?????
- Darrien
- Car Model: Mk2 Jetta
looking to find out if a std abf piston protrudes the bore? and if so by how much? reason being is i want to tighten the squish clearance without touching the bottom end,so i want to make a custom headgasket to do this,thanks in advance.
Re: does a std abf piston protrude the bore?????
Afaik yes. Don't do it. Custom headgasket will bring you headaches. Bent valves and repairs on a 16v is expensive. Valves, guides, gasket set and replacing pistons, rings and bearings.Darrien wrote:looking to find out if a std abf piston protrudes the bore? and if so by how much? reason being is i want to tighten the squish clearance without touching the bottom end,so i want to make a custom headgasket to do this,thanks in advance.
Best bet is to strip your head off and measure if you want to get the correct neasurement. We can give you values, but we don't know if your motor was opened up before and if head was skimmed or block decked. Might still be unopened though.
- Darrien
motor is unopened as far as i know,well im under that assumption as well because the intake gaskets and tappet cover gaskets were still original when i opened it up to sort a leak
- Darrien
thats just an assumption though,assuming all is std,just wanna get the squish down to 0.8,ive done it on the 8v plenty of times with larger cams than i plan to use on the 16v (268intake-272exhaust) and never had a issue,papajo -thanks for your responsse
0,35mm would be the amount of protrusion above deck on a std ABF motor. 0.8 on a 16V is not advisable as you risk hitting intake valves unless your valve timing is spot on. Stretched cam chain and floating valves and kaboom!! I would not go less than 1,6mm valve to piston clearance.
Thinner headgasket does up the compression ratio by a small margin, but ask yourself if it is worth the risk. The thinnest headgasket available is 1,6 mm or 1,65 mm when torqued down. Victor Reinz head gasket. Guys are yousing the 2e steel headgasket too, but I don't have specs on the 2e headgasket.
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Current rides:
Hyundai - 1.4 Getz (daily)
- Darrien
i meant 0.8 clearance on the squish,not piston to valve clearance
- Darrien
if you say that the piston protrudes 0.35 above bore and with a 1.6mm head gasket,its safe to say my quench/squish clerance is now 1.25mm,lowering that even by the slightest bit will help the motor perform more efficiently,and the only ways of lowering it is either deckind the block and using std pistons,getting aftermarket high comp pistons or fabricating a thinner gasket
-so the gasket is the only way i see without touching the bottom unless you can advise me otherwise
- Car Make: ShitiGolf + CRX
You really cant risk advice from other members, the best builders wont even risk giving advice.
clay your motor first and make your own measurements, thats the only safe way to do it.
- chucker02
- Car Model: Citi ADY
How much do you expect the cr to increase by? You wont notice the difference anywayDarrien wrote:if you say that the piston protrudes 0.35 above bore and with a 1.6mm head gasket,its safe to say my quench/squish clerance is now 1.25mm,lowering that even by the slightest bit will help the motor perform more efficiently,and the only ways of lowering it is either deckind the block and using std pistons,getting aftermarket high comp pistons or fabricating a thinner gasket
1971 VW beetle
1971 VW beetle
Smalker clearance on squish result in smaller piston to valve clearance too. Thinner head gasket bring the valves closer to piston.Darrien wrote:i meant 0.8 clearance on the squish,not piston to valve clearance
-=sT3V3=- wrote:You really cant risk advice from other members, the best builders wont even risk giving advice.
- Darrien
thanks for all the replies
- Car Model: Mk5 gti
I hope im not been rude but I'd really like to know is the reward greater than the risk ? Does this setup really make such a big difference ? There are so many other mods that can give u much more power with much less risk ...
viewtopic.php?f=11&t=217296
Previous :too many to list
- ICE King
Check out Torker rides threads, he built motors to extract every single kw out of it.Was/Is a fully built Ethanol motor eventually he craved more power and ended up going turbo
- ICE King
The sort that needed ethanol.
Here's a link to one of his ride thread https://vwclub.co.za/forum/viewtopic.ph ... &start=925
