2L head on 1.8L block
JTL
Registered for: 7 years 10 months
Post by JTL »
Hi guys Im new here
Just need some advice Im running Carb with a 1.8 block and 2.0L 8v head.
Wanna know if what must i do if i wanna fit a supercharger with 36 dcd carb?
My motor was done recently by myself and runs great. I have increased the bore size.
What i would like to know is :
Do i need to port my head?
Do i need to put a stronger gasket on?
What pulleys do i need?
chucker02
Car Model: Citi ADY
Re: 2L head on 1.8L block
Post by chucker02 »
Will be a waste of time with a carb
1971 VW beetle
drop compression ratio for a start. port head not needed to be able to run it.
pulleys will depend on the charger. no way we can just tell you like that with NO info.
suck through carb setup with charger. yeah really not ideal.
JTL
Post by JTL »
Okay so how much do you guys think it would cost to fit mp9 with management?
I'm already running EFI head?
Must I upgrade My tank?
And what will my end cost be like with tuning and everything?
Honestly you are not supplying enough info for any of the answers you expect back.
But as i said the otehr day R60k to 80k for a properly executed turbo conversion and it will be roughly the same for supercharging.
Registered for: 13 years
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
JTL wrote:Okay so how much do you guys think it would cost to fit mp9 with management?
Must I upgrade My tank? I dont see you mentioning what car you have?
And what will my end cost be like with tuning and everything? do you already have the fuel rail, injectors, management?
JTL
Post by JTL »
No i do not have the fuel rail and stuff yet.
And i have a make2 jetta clx
With 1.8 block and 2l ady head
I can get a complete mp9 intake for R1200 and mp9 loom for R400
What i want to know is what else do i need?
What must I do with my original tank replace it, Or can I just fit an inline Electronic Petrol pump?
And how much can i get a management for?
And do i need a three pin coil?
Or will my original coil work? (I have the bottle type coil)
Do i replace my dizzy?
EvanPeter
Registered for: 3 years 10 months
Re: 2l fuel injector head on a 1.8 block
Post by EvanPeter »
Hi guys can any1 tell me if my vw fox 1.8 carb will have more power if I do a conversion of a 2l fuel injector head on a 1.8 block with dictator management
chucker02
Car Model: Citi ADY
Post by chucker02 »
EvanPeter wrote: Sat May 30, 2020 8:31 am Hi guys can any1 tell me if my vw fox 1.8 carb will have more power if I do a conversion of a 2l fuel injector head on a 1.8 block with dictator management
Yes it will but not by much. You will need a new non vacuum distributor. Management will set you back another R4k, gaskets and engineering for the new head will come to the price of a import 2L engine. You will get way more power with a 2L then you would with the 1.8. Much more torque aswell. What is the condition like of your 1.8?
1971 VW beetle
EvanPeter
Post by EvanPeter »
EvanPeter
Post by EvanPeter »
chucker02 wrote: Sat May 30, 2020 9:57 am
My 1.8 is still in good condition its driving I just want to do a conversion thou, I have the management
chucker02
Car Model: Citi ADY
Post by chucker02 »
EvanPeter wrote: Sat May 30, 2020 10:06 am
Ok then go for it. Should pick up a few kw's and improve driveability. Fuel injection is better in every way.
1971 VW beetle
Royden
Post by Royden »
Good morning guys, my apologies for jacking this post, Im new to this forum and my question is quite the opposite. I have a Mk2 jumbo, HM block 1600 head (head has been ported and flowed). I would like to change the sub to 2l but keep the head, is this possible or MUST i get a 2l head?
UDC
Membership No: 1041
Post by UDC »
Royden wrote: Tue Jun 02, 2020 8:49 am Good morning guys, my apologies for jacking this post, Im new to this forum and my question is quite the opposite. I have a Mk2 jumbo, HM block 1600 head (head has been ported and flowed). I would like to change the sub to 2l but keep the head, is this possible or MUST i get a 2l head?
Will work fine, get the 2ltr head gasket set, exhaust may need more clearance if it's a long block, rather upgrade the exhaust system so the 2ltr can breath better if so
Boizen 1
Registered for: 2 years 8 months
Post by Boizen 1 »
The block is been bored 20000 .the car sometimes miss fire as if im losing petrol pressure or maybe the injectors are over spraying
Boizen 1
Post by Boizen 1 »
Hello guys its me again my msg was not clear enough i need help . I have 1.8 carb Mk1 the block is bored 20000 i have changed the carb now im using k-jetronic when the car is cold i have power but when its get hot its losing power and also misfires its like im losing petrol psi or injectors are spraying too much any one help please
Sent from my SM-A217F using Tapatalk
Mk2 pere
Registered for: 7 months
Post by Mk2 pere »
Howzit bud sorry for hacking your post but what did you have to change to run the 2l 8v head on the 1800 8v block thinking of putting a 2l Fi head on my 1800 block not sure what must change to do so
