Carb 8 valve head, can it run EFI?
Here's a question for the customisers on the forum and anybody else who might know.
As per the topic of the thread I am curious to know if anybody has converted a carb u flow head to run fuel injection and if it was successful how did they do it and so on.
I am aware that there is some science behind port injection to do with the position of the injectors in relation to the valves. So therefore I am not asking why a EFI head is better, I know that already. I am simply lookin at another angle regarding the next phase of my build and want to satisfy my curiosity regarding the topic in question
Thanks in advance.
Thanks in advance.
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Re: Carb 8 valve head, can it run EFI?
Sarel's done it, he machined a 25mm thick alu adaptor that sat between the FI intake and the head, basically morphing from the keyhole port shape to the oval port shape. Wasn't done for performance, more due to budget restrains on the owners side. Ran well enough at the end of the day. I did a bit of research when I fitted a Rowland manifold on my solid lifter head, I had a choice of using the injector holes in the manifold or in the head. The closer the injectors are to the valve the better the throttle response, if the injectors are further away you get a slight power advantage at higher rpm's due to better atomisation.
Current rides:
Hyundai - 1.4 Getz (daily)
Many years ago also due to budget we also basically used an mp9 manifold on a carb head and machined the head a bit to have that hollow section. It worked ok enough.
Thanks for the replies, I'm glad to know at least its possible.
One more thing the carb head has a water port that feeds coolant to the manifold. I am assuming this was blocked or welded closed for the conversion. Correct?
- zain_c
another q, sorry to OP for the hijack.
I've got a CLX MK2 Jetta, 1800 carb, would there be any issues on fitting an MP9 head with the rest of the MP9 ancillaries (intake/throttle/loom/ecu etc) to my current sub and having everything run smoothly?
Would anything need to be changed on the sub?
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
No issues. Straight boltmover.
- zain_c
thanks Panic!
I've heard that I might need to change pistons to up compression a bit?
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- zain_c
IIRC guy mentioned 82.5mm
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Not neccesary 81mm stock pistons work fine there.cap'ncook wrote:thanks Panic!
- zain_c
great! Thanks missioner!missioner wrote:Not neccesary 81mm stock pistons work fine there.cap'ncook wrote:thanks Panic!
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
The head cc's are the same inside carb to FI. no ned to change anything.
- graham savage
- Colonel
- Membership No: 803
Just ensure you are getting a 1.6/1.8 Mpnaai head, the 1.4 one won't work
I want to find out can i use a 1.4l Injector head on a 2e Long block MK1 Engine ?
Check valve diameter. Otherwise it will bolt on.Pieter94 wrote:I want to find out can i use a 1.4l Injector head on a 2e Long block MK1 Engine ?
Compression ratio will be very high. Would probably ping it's tits off.
Ive got a setup like this but the opposite way. Using a fuel injection head with a carb. Car feels normal but it has a bit of a flat spot on low rpm
