Finding 2L 8v ABA
Finding 2L 8v ABA
How scarce are the ABA engines? Anyone know a supplier who usually has stock?
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
- Wheel Whore
Re: Finding 2L 8v ABA
dont know of ABA but i have a 2e and they very common here
I know. ABA is the crossflow ADY/2E.
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
It's either the ABA or APK that has the silly rocker style cams, make sure you get the one with the head you're after.
I don't think either of those have rocker cams. ABA OBDI and OBDII certainly don't. Have looked through a AQY/APK technical doc before and didn't see a rocker mentioned.
Only ABA I can find looks to be ODBII so it'll most likely have single valve springs, no spring seats (!!?) and cast crank (debatable whether a forged one is any benefit on a sub-100KW motor such as the ABA, except of course the weight of the thing).
Speaking of heads, anyone know how much different ports and valves would be on the APK/AQY mk4 heads compared to a Mexico or "Germany" ABA head? I looked last night and seems the Mexico ABA head leaves a bit to be desired.
- Registered for: 5 years 5 months
Good day Guys,i know this is an old forum,any luck in finding one as i am curious to know if there are still any around? Would not mind one if i end up with a Jetta 2?
