1.8 carb engine specs
- Registered for: 21 years 2 months
- Car Model: 2017 Cross Polo 1.2 TSI
Hey folks
Anyone have specs for the 1.8 carb motors from mk1, mk2 golfs and jettas? Not familiar with them at all and looking online earlier today I only found info showing some rather pathetic outputs of 60 something kilowatt.
Have a lot of work to do on my mk1 but have to wait for tax season to be done. Enough work on the list to possibly warrant dropping the motor out the car so have been mulling over whether I'd just slip a 1.8 carb motor in there. Budget providing of course.
Sent from my GT-N7105 using Tapatalk 2
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
1989 Audi 500 turbo (the end. finally.)
- Goldwagen Delarey
- Car Model: GOLF 1 1870cc 8v ethanol
- Membership No: 1800
Re: 1.8 carb engine specs
Do you want to know what the std kw output is or what you can achieve when you throw large chunks of money at it ?
Standard output. Have no intention of adding to it.
- Car Model: MK1
hi,
I have a 1.8 motor (HV) that I want to use with my old 1300, 4 speed gearbox.
When the block was mounted with the gearbox, and bell-housing bolts were tightened, the engine refused to turn, with the fly wheel jamming on the bell-housing.
any help would be much appreciated.
thanks.
thanks.
That's kind of irrelevant to the topic on hand.
Anyway ... you use the clutch and flywheel from the 1300 or the one on the 1800? Use the smaller flywheel clutch from the 1300 4-speed combo.
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
From my owners manual for mk2,
1800 16v fi 102kw
1800 8v fi 82kw
1800 carb 70kw
1600 carb 60kw
1800 16v fi 102kw
1800 8v fi 82kw
1800 carb 70kw
1600 carb 60kw
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Car Model: MK1
sorry, just needed urgent help.
currently using the clutch and flywheel from the 1300, and it's jamming when the flywheel bolts are fastened.
Thanks. Wish I had the cash and time to get a 1.6i motor but there's too much that'd need doing to get such a thing in quickly.VWicked wrote:From my owners manual for mk2,
1800 16v fi 102kw
1800 8v fi 82kw
1800 carb 70kw
1600 carb 60kw
Well I think time to budget and search. Looks like we'll be having this car for a looooong time to come.
Can you see where it's jamming?desigank wrote:sorry, just needed urgent help.
I honestly can't think of why it'd be getting caught on the flywheel with all things being the same.
Take it out of gear! j/k
- VWicked
The biggest issue you have is the whole carb story. I am certain if you were to put fi on a 1600 originally carb motor you will make the same power (74kw) as a velociti 1.6 etc2226cc wrote:Thanks. Wish I had the cash and time to get a 1.6i motor but there's too much that'd need doing to get such a thing in quickly.VWicked wrote:From my owners manual for mk2,
1800 16v fi 102kw
1800 8v fi 82kw
1800 carb 70kw
1600 carb 60kw
I don't doubt that for a split second. However, only considering the idea 'cos it'd be a straight drop and fit. I'm sure the bills for FI would grow fast and no can do right now with spending every arriving penny on the kid's needed care.VWicked wrote: The biggest issue you have is the whole carb story. I am certain if you were to put fi on a 1600 originally carb motor you will make the same power (74kw) as a velociti 1.6 etc
So, ja, stuck with a carb setup and currently an unknown budget.
Might, as usual, just not happen. Poor car is need for new driveshafts, clutch, mounts, bearings, hubs, shifter bushings, brakes, etc.
- VWicked
I would advise to fix what needs to be fixed to get the car safely running (especially if you have a young child) mods will come later.
I have many things that I want to do to my car but for now it gets me from A to B and i have just done what needs to be done to make it safe.
Oh no, definitely, that's the plan. But as I said it's a temptation to do the fit at the same time, hence the homework.
Hell, I'm not even thinking of it as a mod.
Hi guys .. sorry if this sound like a dum question but i bought myself a fox 1.8 carb and on the gps I get about 110 km/h to 115 km/h and then it sound like the car is at max refs with the gas pedal down at the floor and on a straight road .. dont know if that is what the speed should be at or is their something i can look at ... Your help wil be appreciated..
Re: 1.8 sub with 1.6 head
Good day gents..... I would like to know what will the outcome be and power figures if I use a 1.8 block with a 1.6 head that's ported and a 276 estas with management
